Question about Neff 24 in. S4443 Built-in Dishwasher
Neff dishwasher will not switch on , checked fuses etc and positive that power is going to the machine but will not switch on,is there any safety feature such as blockage or otherwise stopping machine from switching on, red lights not coming on, machine 4 years old and very little use? can u help
Just went through this myself. It could be a latch switch. Open the door undo the screws that holds on the inside door panel remove the latch. The 2 black boxes with wires attached are the switches. Take them out (use your camera so you know how to put back together), take to an appliance parts place, and have hem check them. Mine were fine saving me $42.00. If this isn't it (as mine wasn't) check the in-line fuse. From the switch follow the wires into the electronics box (you will have to remove the cover. The fuse on mine was attached to the top of the circut board and it had two Tan wires attached, one of these wires attaches to the latch switch. I had it tested and yep it was bad for $12.00 I had a working dishwasher, saving me lots of $$$$$$$. I hope this helps..
Posted on Jul 26, 2009
Neff S5443 dishwasher needs to be reset
If the machine is pumping when on but door is open this indicates that water has gotten into the base (under the tank) and activated the flood safety device. You need to get the machine out, pull on to a towel and tip forward ('lift back feet off the floor approx 45 degrees and let the water flow out. This we deactivate the safety and the machine should now work ok.
Apr 12, 2013 | Neff 24 in. S5555X0GB Built-in Dishwasher
No power lights
Check circuit breaker to see if it is on, Then check the wall outlet to see if you have power to the machine. Turn off the breaker and open the control panel. See if there is a blown fuse. If the fuse is either not there or is not blown, turn the breaker back on and CAREFULLY measure the input voltage to the control panel main switch. If it is not there, check the door safety switch to see if power is there...Lots of troubleshooting...Have fun!
Dec 27, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
Fuse intact in supply lead but Neff H5470NO appears 'dead' - nothing working and no indicator lights is there another fuse ?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 16, 2011 | Neff H5470 Microwave Oven
Dishwasher will not turn on, power check done, please help
this looks like a power supply problem if you are sure you are getting power right up to appliance it can only be a electronic failure pcb open circuit etc anything else and the lights would still illuminate.
Jul 25, 2009 | Neff 24 in. S5444X1GB Built-in Dishwasher
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
My dishwasher does not turn on
check socket is ok - plug in something with a light into the same socket as an easy way of checking. otherwise go to where mains terminates on the appliance and check power is actually present - you will need a multi-meter
Jun 19, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Feb 18, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwasher is tripping off our safety switch
It depends on what kind of test he was doing. He was probably checking the amp draw which checks how much power the whole machine was pulling. This would be the way to check the problem you have as long as he checked it with everything running, motor, heater,..etc. If you find the amp draw to be too high, then you go to individual components.
Oct 04, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Neff 24 in. S4443 Built-in Dishwasher Logo
1,278 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
