Question about Dyson Washing Machines
Dyson Hot and Cold. How to clean filter on hot and cold fan base. Dirt in filter wont come out with suction?
chrispurs1
  • 372 Answers
SOURCE: Dyson DC 14 Animal is not sucking dirt
Hi All.
You have blockages check all the hoses & inspection ports onw at the back (U) shaped & one to the front left of machine.
Pull wand from flexi hose check for obstructions.
Remove long flexi hose from the rear of machine again check for blockages.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 26, 2007
Bloomingidoi
  • 49 Answers
SOURCE: Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Posted on Dec 03, 2008
SOURCE: Dyson has lost suction and loud noise from base(?),
I had the same problem, from right out of the box. Now that I just threw mine out, I see this site that indicates there's a fix for it:
http://ths.gardenweb.com/forums/load/cleaning/msg0415060828462.html
And search for other sites isung "dyson grinding" or similar.
Since I was an early adopter (had one as soon as they came stateside), I did not have the benefit of countless others having the same problem, I just attributed it to a junky design, since so much else about this vacuum was poorly designed, like the seals, hoses, etc.
Give them a call, and good luck! I might rescue mine from the heap and do the same.
Posted on Apr 08, 2009
ukvacfan
  • 328 Answers
SOURCE: no suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Posted on Jun 19, 2009
  • 33 Answers
SOURCE: dyson has lost it's suction
The filter housing can also be an issue. Check this:
http://www.ehow.com/how_5870417_modify-dyson-prefilter-suction.html
Posted on Jan 26, 2010
Have a dyson hot cold fan keeps saying h2 and heat wont work any advice tried inplugging works for a few minutes then stops saying h2 again
Doesn't that mean that it had reached 'Heat 2'? Have you tried increasing the heat setting?
If you have, contact Dyson Warranty Department. Tell them Fixya sent you.
https://www.dyson.com/support/am04/am05-iron-blue/diagnosis-root-menu/machine-not-heating-am04
Dec 14, 2016 | Dryers
Dyson hot and cold fan wont turn on
Inside the electric field there is an insulations tape inside the coil in a most white or black colored tape where these temperature fuse is broken or also fuse in the powercable
Dec 17, 2013 | Dyson AM04 Hot Cool Fan Heater White
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
8 year old side by side, refrigerator and freezer not cold, compressor running, condenser fan running, discarge line not hot suction line not cold
discharge line not hot suction line not cold. This indicates the compressor is not working properly. It could be out of freon or just not pumping.
Nov 03, 2010 | Maytag Refrigerators
Dyson lost suction
I found out that it was the sponge filter bit which needs washing every 6 months in cold water, this sorted it out as I had never cleaned it before
Dec 06, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hose is not getting any suction
when vacuums shut off randomly it usually means they are overheating. this can be caused by a clog somewhere in the line of suction, or, perhaps due to a very dirty filter - either way, the motor is working hard and getting too hot.
try removing all the various tubes and parts along the suction route and checking for clogs (a flashlight might help too). also, have you rinsed out your two pre-filters lately as recommended in the Dyson manual? it might help.
Apr 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Washing Machines Logo
63 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
