Question about Canon Office Equipment & Supplies
My mx922 after being in sleep mode it reconnects to the wrong router ID. My last canon Printer did the same thing and never did get it fixed
SOURCE: sleep mode on x2gen
me too
Posted on Aug 28, 2008
  • 76 Answers
SOURCE: Canon IR7105 inmage runner.Sleep mode??
just press the power button! if not you have a problem on all day power supply.
Posted on Dec 09, 2008
  • 34 Answers
SOURCE: Reconnecting to internet after recovering from sleep mode
There are many causes of this, but the most common can be solved by going to the CMOS (BIOS) of your computer and disable the power saving on the ethernet, PCI or wathever where you modem is connected.
Posted on Jul 18, 2009
SOURCE: Connectted to a router, does't wake up from sleep mode
uplod photo
Posted on Jan 23, 2010
SOURCE: Wireless disconnect in sleep mode?
I think that is normal to conserve energy. There are times when it will take the network connections down to conserve energy.
If it is a problem you can always increase the time on the sleep mode or set it to NEVER.
Posted on May 13, 2012
Canon MX922 printer: cyan was okay after installing new cartridge, but quit printing blue after a few days. Multiple deep cleanings were no help. Can print head be removed?
You better buy a new cartridge, or you could fix that open the cartridge on your printer device.remove the cartridge and broom with a Kleenex.If you need the driverpleasehere Canon PIXMA MX922
Mar 20, 2017 | Canon Pixma MX922
I am researching the Canon MX922. Will it print on cardstock and if so what weight? Also, is it compatible with Vista.
If you wantCanon Printer Customer Service Phone Number, then you can contact with us Canon Printer Tech Support Phone Number#1877-778-8@9@6@9.We are always here with tech team for your help. For further information Click:
Aug 15, 2016 | Canon Pixma MX922
Computer and printer suddenly won't communicate over wireless network. Multiple reboots, reconnects to network and re-downloading the driver didn't help.
Hi Bruce, It's probably your Wi-Fi connection that has lost the connectivity. Your password or simply your Modem needs to be rebooted.
The link below will guide you a bit.
Feb 28, 2016 | Canon Pixma MX922
Canon mx922 error message needs repair
It is likely that the print-head temperature sensor is detecting an over heat. If that is the case, start thinking about a replacement machine as the printheads are expensive to replace.
Feb 22, 2015 | Canon PIXMA MX922 Inkjet Multifunction...
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the error, the unit would require service:
May 03, 2014 | Canon Pixma MX922
26 people viewed this question
old marine
old marine
