Question about Sony Televison & Video
Sony kdl55hx800 no sound picture. did flashlight test nothing no backlighting. i was thinking it was the power supply
The green light on the front works as well as the optical sound out red light. ive had it on for a while just for fun and it clickes that sounds like it is coming from the power board the green light after about 30 secounds will turn off then on again, makes me believe it is the power board
    Top Expert:
  • Sony Master
  • 39,460 Answers
Probably a failing power supply
Posted on May 08, 2017
I have a Samsung UN55H5350. The picture went out while watching Netflix. There is still sound. I took the back off and tested the backlight and they are not coming on. I also tried the flashlight test and...
You should see something on the screen if just the backlights were out, do you have sound?...Measure the voltage going to the LED lamps and see what you have there...It should be somewhere around 100 volts give or take
Dec 30, 2017 | Samsung Televison & Video
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
My LG tv (Model number: 32LS3410-UB) has sound, but no picture. When I do the flashlight test I can see a very dark image on the screen. Will replacing the LED driver fix this problem?
If you already tested with the flashlight which is the first step in the blank screen with sound fault then you have to test the LED Backlight supply voltages if you are familiar and good in the electronic repair. First you have to check if bulging capacitors for the LED Backlight drive voltage circuit, replace them. If capacitors are good then you have check the backlight LEDs. The flashlight test proves that the power supply is good and TV is working fine because the sound is ok and picture is fine. Attached videos and links may help you for the repair and replacement of backlight LED strips or LEDs itself depending on the type of LED strips used in your model.
https://www.youtube.com/watch?v=Z1DEkSguWtg
https://www.youtube.com/watch?v=YgaL6X6eSaU
https://www.youtube.com/watch?v=EZVQKEp6jxk
https://www.youtube.com/watch?v=T2FboV-1PJg
https://www.youtube.com/watch?v=2pyuXwNkBMA
May 08, 2017 | LG Televison & Video
Tv has sound but no picture, nothing shows with the flashlight test, all inputs have sound but no picture, installed a new t-con card with no results ?
Use a voltmeter to verify the different voltages on the power supply board are present within tolerance. Look for discolored , puffy or domed capacitors. Repair kits and complete replacement boards can be had from: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 17, 2016 | LG Televison & Video
About the Sony Bravia Kdl55hx800 55" Lcd Tv
The 12 volts comes FROM the power supply board.
TV Parts Universal TV Stands DLP Chips ShopJimmy Go to this web site. You will find repair parts kits as well as complete boards there.
Dec 31, 2014 | Sony Bravia Kdl55hx800 55" Lcd Tv
No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
May 20, 2012 | LG 19LH2000 19 in. TV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
