Question about Microsoft Xbox 360 Wireless Controller
Every time my controller gets to 3 bars it turns off constantly
Always 3 bars
works fine when full
works somtimes on 1 bar
    Problem Solver:
  • 10 Answers
Get a new battery pack,i had the same problem,if its a rechargeable battery pack,then seriously get a new one.recheargeble battery packs always have lots of problems.
Posted on Jul 26, 2009
Our Jazzy Select G.T. power wheel chair won't run. The lights keep blinking when the power is turned on but won't run..? Why? Battery is charged.
Hi
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mi mobility
Feb 18, 2011 | Pride Jazzy Select 6 Indoor Power...
Trane XR80 blows cold air. Inducer motor comes on, glow bar glows for few seconds than goes out and inducer motor shuts off. Immidiatly after the main blower comes on and blows cold air. Will blow until...
I know that it's easy to spend someone elses money but in my experience when you get one actig that erratic it's usually the control board. I would check all the wiring including thermostat. You never know you might get lucky. I hope this helps you. Thanks
Nov 29, 2010 | Heating & Cooling
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Car - interior fan control working but only on full or 1 bar
switch is bad look in salvage yard for new used arts
Jan 17, 2010 | 2005 Mazda 3
The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
Oct 01, 2009 | Lexmark X6570 InkJet Printer
Husqvarna 136 chainsaw
Both H and L screws should be set 1-1/2 turns out from stop. Turn the idle speed screw two turns in from where it is now. When you had the carburetor apart, did the rubber diaphragm seem hard? If it did, re-kit the unit. When you clean the carburetor body, use spray carburetor cleaner and use compressed air to blow out all fuel passages including the two mixture control screw holes. Be sure to check the condition of the fuel line and the air cleaner. Even a plugged muffler can cause weird problems.
Aug 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
GHWT(PS2) loading bar freezes when it is full
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER $50-75 CALL FELTON (870) 733-1375
Dec 26, 2008 | Sony PlayStation 2 (PS2) Console
Vertical Bar on JVC VM42WV74
A vertical bar can be caused by a number of things. A couple of possibilities:
1) Bad connection to panel at that vertical location.
2) Defective processing chip.
3) Bad panel
Any of the above could be the problem. Some experimentation and measurement would be necessary to determine the exact cause.
Dan
Apr 09, 2008 | Televison & Video
Mio 168
Have you found a solution ?
Nov 08, 2007 | Mitac Mio 168 Pocket PC
Microsoft Xbox 360 Wireless Controller Logo
131 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
