My theracell will not stay lit. It works for a few minutes and the indication light goes out. Plenty of fuel
dgjtex
  • 405 Answers
SOURCE: Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be generous..lol
Posted on Dec 19, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
bill_48632
  • 149 Answers
SOURCE: Laars Lite 2 LG - pilot light will not stay lit.
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Posted on Aug 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Kirkland Patio
Hi and welcome to FiXya I am Kelly.
Your pilot light burning yellow is a sign of a dirty orifice. This can be caused by insects or a spider web in the pilot air supply.
To clean the air supply / orifice area see this page:
http://www.nexgrill.net/trouble/p1.5.html
Also the thermocouple may not be close enough to the flame. You won't know this for sure until you finish cleaning the pilot / orifice area.
This link has step by step links for all of the components / causes of a pilot not staying lit. Click each of them and it will bring up a pdf file with step by step instructions and pictures:
http://www.nexgrill.net/trouble/p3.html
A bad thermocouple can also cause this. Givien you have a yellow flame I do not think this is your problem. But if it ends not staying lit after cleaning see this page on how to get to the thermocouple:
http://www.nexgrill.net/trouble/p2.2.pdf
Thanks for choosing FixYa.
Kelly
Posted on Sep 05, 2010
SOURCE: Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Posted on Sep 29, 2010
I HAVE A BAND NEW KFA80DGD MODEL. I USED DEISEL, IT LIGHTS AND FAN BLOWS BUT AFTER A FEW MINUTES THE FLAME GOES OUT AND IT SHUTS OFF. THE INDICATOR LIGHT BLINKS...
there are two different viscosity rates and two different calorific values here
if it worked well on kerosene keep it on that
if you want to use diesel then have a technician come and set it up for diesel
Jan 04, 2017 | Heating & Cooling
When i compress the propane knob for the pilot light, the whole element has propane run through it. Then when i let go of the pilot to run gas to the element, the flame goes out...? Pls help. Its brand...
Hold the knob down for at least three minutes after lighting the pilot. This give the thermocouple plenty of time to heat up and should stay lit.
Sep 04, 2011 | Heating & Cooling
Pilot will light and stay lit for 1 to 2 mins. Logs lit once but only for about 30 secs. There is NO gas flow after the fire goes out. If you wait a few minutes there is enough gas to repeat this same...
this is closely guarded secret. get a can of air for dusting computers and lightly blow dust out of piolit assembly.I've made allot of money doing this.merry xmass.if this doesn't work then you probbaly need a new part.or if piolit is too small it might need cleaning.
Dec 24, 2010 | Heating & Cooling
Pilot will stay lit but burner goes out about 1 minute after it lights
Sound like the flame sensor you could scratch around on it and try again.Possibe venting issue
May 14, 2010 | Water Heaters
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
The burner will only stay lit for a few minutes
Hello. Begin by using a small brush to clean everything in that area. Then light the pilot and light the burner. If it still acts up, change the thermocouple. Regards, joe
Nov 22, 2009 | Computers & Internet
My low fuel light is flashing, What does this mean? It is also very slow to indicate fuel level.
Modern bike have a two stage fuel level indicator. Flashing then solid yellow. Usually you have 5 to 10 miles when you see a flashing yellow light and about 1 mile or less when the light goes solid. Older bike had a shut-off valve and a reserve switch. You turn the switch to reserve once you bike starts to sputter or stall.
If the fuel light stay lit even after you fuel up then the sensor need replacing. That sensor in inside the gas tank.
Aug 11, 2009 | 2004 Yamaha Road Star Silverado
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
