Question about Craftsman Garden
I have a Craftsman Dyt 4000--24hp and 48"deck. It seems as the transmission is leaking a little at a time. Can I add transmission oil to this sealed unit? Model944-604002
    Master:
  • Craftsman Master
  • 645 Answers
This unit runs a Hydro-Gear transaxle. If you add oil, add 20W50 full synthetic motor oil.
Posted on Dec 13, 2017
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
  • 7 Answers
SOURCE: The right transmission on my
The type of oil I would use would be fully synthetic motor oil, 5w 30. It is basically the same as hydraulic oil.
Posted on Mar 10, 2009
  • 234 Answers
SOURCE: rear main seal leaks..does this affect transmission??
A leaking rear main seal will not cause your transmission to leak.
The transmission has its own seal and should not leak because of the engine rear main seal.
Due to the labor involved in replacing the rear main seal on the engine, it is best if you replace the front transmission seal at the same time if possible.
Installation varies on different vehicles but the principles are the same.
Posted on Apr 15, 2009
  • 677 Answers
SOURCE: front fork leaking oil from bottom of the seal.
Before you take it to the shop try this.Get some camera film,Cut the notched edge of it and trim the top to an angle of 45 deg..Slide this up into the fork seal and working it up and down,slide it all the way around the seal.When you get the feel of it,you can feel tiny bits of grit.This will clean the grit out 99% of the time.I always keep a piece of film in the toolbox.
Posted on Jul 16, 2009
SOURCE: oil leak problem with 1996 toyota camry
I am going to see a mechanic - my trusted mechanic who does not nickel and dime me - to see what this is. I have the same problem and he told me he has never done this job on a Camry and is unsure. Given the miles, he has suggested that maybe it is time to part ways with the car. I am going to ask him if he will put some florescent dye in it and let me drive it for 50-100 mi and then check to see where the leak is and fix it. Let you know what happens. I have to try, the car is solid.
Posted on Aug 15, 2009
Husqvarna riding has a puddle of oil under deck I don't see we're it's leaking help
it may be the main shaft seal. I will recommend washing it then try to look for it.
May 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine leaking oil at top
The crank seal needs to be replace. You will have to remove the fly wheel.
Jun 21, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a DYT 4000 from 2004. Cutting the lawn today, about half way through something inside the engine popped (sounded like a belt) and the tractor shut off. I tried to restart and the starter was FLYING...
Sounds like an internal engine failure. Take the spark plugs out and stick a screw driver in the the cylinders. Then turn the engine by hand, and see if the pistons move. My guess is one or both won't, but if they do then you'll need to do more testing like a compression test or leak down tests. You may even need a partial tear down to find the problem. Sorry to be the bearer of bad news, but it is possible that it is repairable rather than having to purchase a whole engine.
Oct 03, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
24 hp intek has no power when under a load mainly when blades are engaged blows smoke like crazy.i pretty sure rings are shot,but the no powers got me stumped. valves are adjusted properly. i thought it...
I have good news for you,well sort of,the rings are probably ok.The intek engine is noted for blown head gaskets.They leak between the cylinder and the push rod chamber.A way to check is to start the engine for a minute,turn it off and pull the dipstick out,if you see vapors coming out of the oil fill tube it has a leaking head gasket.To check to see which cylinder is leaking, check the plugs,there will be a oil residue on one or even a brown crusty build up on the side that has the leaking head gasket.If you remove the head you will probably see a small piece of the gasket is missing on one side of it.
Aug 11, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
