Question about Sanyo DS25390 TV
Sanyo DS25830 and DVD player...
I have a used Sanyo DS25830 TV and just bought a cheap DVD player... problem is there are no jacks anywhere on the TV! Is there still a way to connect the DVD or am I out of luck???
  • kenkin Dec 25, 2007
    I have the same exact problem and the dam VCR book don't have a diagram for that hook up. Keep changing everything every few years. It's the american way.
You need the converter box
Posted on Mar 19, 2008
An RF converter from Radio Shack, Walmart, KMart, or wherever will allow you to make the connection... only problem is that it will cost as much as a cheap DVD player which defeats the purpose of the original expense.
Posted on Dec 26, 2007
Did you ever fix the problem if so I would like to know how cause it don't look like anyone has helped you and I would like to know if the dvd can be hooked up to this tv?
Thanks
Posted on Dec 25, 2007
My sanyo tv picture wont come on except when you first turn it on then it goes off, the sound works
Have you tried using a different input like a DVD or Blu-ray player with a HDMI cable? If you get the same issue using a different device and a different input then it is possible the Input board in the TV is fried, lucky all the boards in LCD/LED TV's are real easy to replace and individually are fairly cheap.
Jan 02, 2015 | Sanyo Televison & Video
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
No audio when using VCR/DVD player
the first thing that you need to do is use the video cables and audio cables that are on the back of the unit. This makes sure that you have sound and video.
Dec 22, 2008 | Sanyo DS27510 27" TV
FUNAI DVD/VIDEO CASSETTE RECORDER WITH HDD
connect the antenna or cable to the aerial jack of the funai. connect the rf out jack of the funai to the aerial jack of the tv .connect av1 scart jack of funai to scart
jack of tv.
The discs to try are cheap discs from poundland called mr dvd-r they seem to work
Sep 23, 2008 | Funai PY90VG DVD Player/VCR
My Sanyo DWM-400 plays some DVD's and won't play others.
I bought another DVD player. I found out that all DVD's don't play on all DVD brands of players. They are cheap enough these days so I decided it wasn't worth a repair bill. The Sanyo DWM-400 plays many of my store bought DVD's and not others. I never tried a home made DVD in it so I don't know how it responds.
Jun 22, 2008 | Sanyo DWM400 DVD Player
Hook up dvd(nexxtech edp3110) to emerson ewv403 and then to sanyo tv(ds13204)
Hey why dont you use a video sender incase your intrest is the picture and then search the channel on tv
Mar 21, 2008 | Emerson EWD7003 DVD Player
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
Please help
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Jan 09, 2008 | Sanyo DWM400 DVD Player
Televison & Video Logo
260 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
