Question about Freezers
Homak chest how to remove slide to keep it from droping
The chest freezer was open wide for 24 hours before I noticed it. Will I have a problem with the unit or will it be fine
as cold air sinks to the lowest point it would have been operating a little longer that if it was closed I would think that it will be fine
example chest freezers in supermarkets only have plastic sliding lids and the ice creams and other frozen foods are still frozen
Apr 28, 2016 | Freezers
How do you remove drawers from craftsman 26" quiet glide middle tool chest?
My Craftsman rolling tool chest has bearing glides. Open the drawer all the way and look at the drawer glides. One each side there is a small black lever to release the drawer from the glides. One will move upward and one downward by pushing on the beveled side and pull the drawer out.
Jan 03, 2013 | Tools & Hardware - Others
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Freezer/kenmore
    the settings usually are:
    off - on - superfreeze. you just want "on"
    Nov 16, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
    Excess frost not keeping food frozen
    you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
    Apr 14, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
    Keep resetting!!!!
    Sounds like an alarm to warn you something is wrong with it. I would have a professional look at it.
    Jan 08, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
    Freezers Logo
    60 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    AJMAL KHAN
    John Tripp
    John Tripp
    Are you a Freezer Expert? Answer questions, earn points and help others
