Question about Intex Pool & Spa
My intex pur bubble spa says e96 one filter has suction other one doesnt
8880u81
  • 3103 Answers
SOURCE: I need filter cartridges for Intex Spa
sometimes these can be hosed off with a garden hose and reused a couple of times..
Posted on Mar 06, 2014
jerry_kramer
  • 3904 Answers
SOURCE: intex spa
You have a bad GFI plug. Replace it and you should be fine.
Posted on Apr 13, 2014
  • 1631 Answers
SOURCE: Please help I have a intex pure spa and it has
According to Intex - E96 is a "System Error", and the most common problem associated with that fault code is a failed GFCI Cord End.
Look here for replacement;
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
Posted on Apr 11, 2015
  • 1631 Answers
SOURCE: Flow issues through MasterTemp 400
I am only asking, because I noticed that you reported that this is a 400,000 BTU heater. And you are speaking of spa jets?
And... You stated that you are seeing pretty good flow coming into the pump, because you can see through the lid of your pump. This provides for me, a red flag. If water is coming into the pump at a good pace, it's got to be going somewhere, right?
you can't have X amount of water coming into the pump and have less then X returning to the spa. If this be the case, then you have an underground leak, and you will be noticing a water loss problem. So... i'm going to take a guess, that this may be a pool/spa combo?
if so, my guess would be that certain valves, are not properly opened or closed. And I would guess that water is returning to the pool, and the remainder of the water is flowing back through the spa jets, that you are reporting.
if this system that you are reporting about, is only a spa, then I will join the club, I too am stumped.
Posted on May 25, 2015
  • 108 Answers
SOURCE: I've got an Intex pure spa hot tub and the air bubbles button isn't working but the LED screen is on??? Any suggestions?
  • Do the other buttons work fine?
  • Did you press REALLY hard and break it
  • Have you tried pressing it REALLY hard when its not broken- Probably a bad idea
  • if you have the know how and the bravery take the face plate off (MAKE SURE THE POWER IS OFF AND THE WHOLE THING IS UNPLUGGED)!!!!!1
  • check the wires going to the back panel of the screen Rusted, corroded? Might be covered under warranty - refer to manual or look-up based on how long you've had unit
Posted on Jun 05, 2015
Sorry what dose e96 code mean
It is helpful to post device (or vehicle), brand, model, and sometimes year when posting a question. For instance, this question was posted in cars and trucks. But as code numbers are sometimes by sheer coincidence shared with other devices, this number is the code for an error related to a spa:
Intex Pure Spa E96 slow reset solution
Aug 08, 2017 | Cars & Trucks
How can I fix code E96 ?
The E96 error code t - the control console (the bottom part with the pump. call intex customer service and order a new one, you need your receipt.
Jan 17, 2016 | Intex Pool & Spa
Why are bubbles forming in my intex pure spa jet massage?
the air bubbler is switched on
there is a leak in the suction side of the pump that is sucking in air
Sep 14, 2015 | Intex Pool & Spa
I have an Intex Pure Bubble Intex Pure Bubble Spa. The filters do not have any suction. Are they supposed to? If so how much? I do not feel anything.
For a test only, remove filters and see if you feel anything against the fitting?
If nothing either 'Air Lock', keeping it from priming the pump.
Or, bad pump!
Secondly, are you still dealing with a problem?
Use the comment link on this thread, and let the forum know if you are, if repaired, what did you do?
Intex link...
Support Intex
Jan 22, 2015 | Intex Pool & Spa
What errors does Intex E96 code cover
make sure pump is primed
Sep 14, 2014 | Pool & Spa
E96 error code
E96 - On what?
Need more info.
Apr 13, 2014 | Intex Pool & Spa
E96 on intex spa pump
I do not know what that error code is however I can tell you most of those kinds of spa take around 24 hours to heat up.
What model name of Intex Spa do you have?
Rod
US Parts Center
Apr 12, 2014 | Intex Pool & Spa
Intex 633 lost suction
I have seen a common problem when customers change / clean their filter is that put the DRY clean filter in the skimmer box or filter holder and sometimes it can cause an "air lock"
Just take your garden hose put in the intake outlet of your pool and turn that baby on....If you start seeing air bubbles on the discharge end of the line most likely that was your trouble.
If the problem still persist then at that time look into pump repair / replacement.
Good Luck!
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
103 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
