Question about Freezers
Homak chest remove slidefrom to keep it from falling
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
Loading
You need to remember heat rises and cold air falls. The best way to load a freezer is to put meats on the bottom. They take alot longer to freeze and thaw and can save your stock if you have a power failure. Keep non-critical things like ice cream, ice, and other thing towards the top for quicker access.
May 10, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
Apr 14, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Keep resetting!!!!
Sounds like an alarm to warn you something is wrong with it. I would have a professional look at it.
Jan 08, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
15 cu. ft. chest freezer
Remove the back panel, if there is one, find the compressor. Put your hand on it. If its very hot, you have a problem. You should feel a slight vibration if good and running. If The overload is shutting off keep your hand there and wait a few minutes, see if there is a clicking noise coming from the compressor. This is just a start, but you said it has been off for a while so my first suspect is a compressor. Do these things and let me know for a follow up.
Dec 20, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
57 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
