Hi have a question on my washer it says STARS TO BEEP F then H WILL LIGHT UP AND IT WILL STOP SPINNING AND WHAT TO DO
2 Suggested Answers
kapishtech
  • 2272 Answers
SOURCE: The washer will stop 2 minutes before the end of
If the washer will fill but won't drain and spin then the motor control is most likely at fault.It will require a live voltage check at the motor control to determine what the problem is.Do you hear the motor running with beeping noise.Also any front panel light flashing with beeping or only beeping is noticed.Does it beeps non stop or pauses after some beeps and continue again beeping. You did not indicate if any lights are flashing along with the beeping. Generally speaking whenever the control is beeping continuously the five vertical lights above the Pause/Cancel button will flash and the START indicator will flash. The flashing lights above the Pause/Cancel button and the flashing START light are indicating an error code. To check what error code your washing machine is indicating.Please click on the link below:--- http://media.fotki.com/1_p,sswqqssgkqktgffxgtqsskgwtqkq,vi/wwqwgqffbxwddfqwkfbxfksqrdkbk/1/1303472/5961857/image1692746404187201893img-or.jpg ----------- Click this link for reaming test procedure:--- http://media.fotki.com/1_p,sswqqstdkwqdkbtxgtqsskgwtqkq,vi/bqsrggswkxsdswtrwfwxsbbsgkqrg/1/1303472/5961857/image6948068420903353406img-or.jpg ----------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 14, 2010
How do I stop the stars from blinking on a fossil watch
Hold button down for 2 seconds to alternate between different modes i.e. Flashing, not flashing, light always on.
Oct 01, 2014 | Fossil Watches
Washer stops mid cycle
Hi there if the washer is doing this it may be detecting it is unbalanced or has too much in it and it will stop it from spinning as if it doesnt it will fly apart when spinning, try halving the load you put in it and if that doesnt help it may be the actual balancers and you may have to get an expert to rebalance it
Apr 10, 2012 | Frigidaire GLWS1349A Top Load Washer
Washer is not draining water , spin and stop spin and stop
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 25, 2011 | GE Washing Machines
Washer stop spining
heatman101
Nov 04, 2010 | Maytag PAV2300 Top Load Washer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My washer won't stop spinning through all cycles
hi..the timer controls the starting and stopping of
each phase of the process.It sounds like the timer
is defective.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
