Question about GE Washing Machines
Reinstalling door window on a ge profile washer mo. no. wpdh8800jomg
2 Suggested Answers
  • 44045 Answers
SOURCE: have a ge profile washer mo.no. wpdh8800jomg need video showing how to put door back together
Check YouTube for something similar.
Posted on May 13, 2017
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Profile dishwasher door won't remain fully open and lay flat.
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
good luck!!!
May 06, 2009 | GE Dishwashers
GE Profile top load washer wont drain or spin
SOUNDS LIKE THE LID SWITCH IS DEFECTIVE, ITS A SWITCH THAT CONTACTS WHEN DOOR CLOSES, THEN RELEASES CONTACT WHEN DOOR OPENS. HAVE A PRO CHECK IT AND REPLACE OR BYPASS IT.............
Dec 14, 2008 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
