Question about Tablets & eReaders
Skygo says my fusion 5 10.1 tablet is a rooted device. I had it scanned and it is not. No answer from Skygo.
Hey i rooted my android tab and its never been the same its stuck on android 3.0.1 can this be fixed?
Rooting a device always has the potential to turn the device into a 'brick' in some circumstances. Most good rooting procedures mention this, as well as steps to make a backup of the current system and how to recover from a failure to boot after rooting. There are also different 'mods' that can be tried to see if one of them will work in place of the one you first chose for rooting. These are all dependent on exactly how Android was modified for your hardware. Google 'rooting' and 'Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR' and see what the articles say. You can also try a hard reset of your tablet and see if that does anything. Example at this link http://forums.androidcentral.com/samsung-galaxy-tab-pro-10-1-rooting-roms-hacks/396031-how-root-your-galaxy-tab-pro-10-1-a.html
Oct 31, 2014 | Samsung Galaxy Tab 101 Tablet...
I am trying to get on my tablet and a message keeps popping up saying that the launcher stopped working. Can you tell me what is wrong.
Well, a core application manager software (the one that helps you find and start apps when you click is broken). Please give a description of Tablet make/model(such as Apple iPad 5, Dell...) and OS name (IOS or Android 2.3 or so) This will help direct you appropriately..
Sep 15, 2014 | Proscan 7-Inch Android Internet Tablet,...
Rooted kocaso m9100 tablet,
How do I set up Parental Filter. It will not pop up and it says not allowed: SPY mouse.
Dec 25, 2013 | Kocaso MID M9100 9 Dual Camera Android 4.0...
How to root nextbook nx007hd
  1. Google and download Cydia Impactor (First result on Google) Extract it (desktop, wherever you prefer)
  2. Enable USB Debugging on your Tablet (Settings > Developer Options > USB debugging)
  3. Plug up your Tablet via USB, do not turn usb storage on, let windows try (and most likely fail) at installing drivers.
  4. Launch Impactor and select USB Driver Scan from the top menu (under USB). Let it do it's thing, reboot your PC after.
  5. Verify your tablet/android device is showing up on the start-bar as being plugged up/in (bottom right area)(this may not be needed depending on your setup)
  6. Relaunch Impactor (if rebooted ) and hit the Start Button
  7. Let it do it's thing.
  8. You should be rooted now go install SuperUser!
Dec 17, 2013 | HTC PG41200 EVO View 7in LCD 4G Tablet
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
Acess root of device
If you want to Root an android device start here rootzwiki.com/
Each device is different so look up your particular device, model # and firmware #. Take precautions when trying to root your device and read up in your android forums about your device and the risks of rooting before you attempt this. Other than that good luck rooting!
Feb 17, 2013 | Tablets & eReaders
I recently recieved a Dell 4sight brand tablet. As of now this particular device has given me nothing but trouble. i have figured out almost every last detail to this tablet, but i dont know how to su
The only thing I can make of your question is you want SU (super user) access, in other words root your tablet. The only way to do that is if someone creates an root image for your device. This is one of the best sites to ask that on http://theunlockr.com
Dec 30, 2012 | Tablets & eReaders
Would rooting my tablet effect any previously downloaded or saved file?
Generally speaking, it will not. But it is always recommended that you make a hard backup of all the data and files saved just in case any emergency.
Here is the safest way to unlock an Android device without voiding its manufacture warranty or any supported services.
Dec 12, 2012 | Coby kyros Tablets & eReaders
I want to root my tablet but it wont root bc on the boot screen it says locked how can i unlock it so i can root it
Go visist XDA's forum and look up the rooting guide for your device. HTC is one of the better manufactures that actually allows for easy rooting.
Dec 12, 2012 | HTC PG41200 EVO View 7in LCD 4G Tablet
Error 7 when i try sky go movies
according to the sky help forums at http://helpforum.sky.com/t5/Using-Sky-Go/Sky-Go-Errors-5-7-amp-9-on-iPhone-iPad-amp-iPod-touch/td-p/208239/page/4
Try the following steps to resolve this issue:
  1. Locate the Sky Go app on your Mobile device.
  2. Hold down the icon until the app wobbles (You will see a White Circle with a Black Cross symbol, press on the cross to remove the app)
  3. You will then be asked to confirm you wish to delete the app - Press Delete the Sky Go App will then be removed
  4. Go back to the App Store and reinstall the Sky Go App. This can be found by searching for BSKYB
  5. Access the Sky Go app again and you should be able to view content after you sign back in using your Sky ID & password.
Hope this helps
Dec 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
75 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
