Question about Garden
How do i replace the drive control cable on my lawnmower
Lawnmowers: How to replace drive cable on Craftsman 700 series Model # 917.374551
Try SearsPartsDirect.com or Parts Tree Repair Clinic they may have a video.
Mar 18, 2018 | Craftsman Garden
My craftsman lawnmower 22 inch with drive control will not engage the drive control
Make sure your drive control is free from dry grass and garbage. Could use some oil on moving parts as well.
Mar 10, 2015 | Craftsman Garden
How do I fix 3 speed lawn mower that won't shift gears
Is it belt driven? check your belt. even if it is hydrostatic check your belt. if you engage through a cable then disconnect the cable at one end and make sure the cable moves freely. if not replace
Feb 16, 2015 | Garden
I have a MTD Model #11B-509B205 lawnmower with constant speed control. The speed does not stay at a high speed anymore. Something broke. What?
IS THE CONSTANT SPEED CONTROL CABLE DRIVEN? IF SO, CHECK FOR A KINKED CABLE, OR REPLACE. CHECK SPRINGS AND LINKAGE AT CARB ALSO FOR BINDING
Apr 05, 2014 | Mtd Garden
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Does anyone know where the springs belong in the Driver Control, for a frontwheel drive rotary lawnmower?
Is it automatic with the peddle? If it is the spring installs from underneath.
Jun 18, 2013 | Garden
Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Jun 02, 2010 | Garden
How to ajusta throttle linkage on riding lawnmower
Near the throttle control assy on the engine the cable has 1 clamp on it. It should be very near the end of the cable shielding. Losen the clamp and move the throttle control until the cable EXTENDS out of the shielding and re-tighten the cable clamp. You may have to do the trial and error on the adjustment but usually is should not have to be moved more than 1/4 inch from the original position unless the cable clamp over the shielding was loose to begin with.
Kelly
Jun 03, 2009 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
