Question about Hudson Garden
My backpack pump sprayer handle is too stiff. Only pumps a couple times then I can barely move it! Please help.
Backpack Model Hudson 63184
    Top Expert:
  • Hudson Master
  • 48,272 Answers
Blockage in a jet or valve
overhaul the pump
Posted on May 07, 2017
Testimonial: "Thanks Bill, but I found something online that said to try petroleum jelly on the inner part of the pump thingy. It worked!"
I put a new diaphram in the pump and now the pump handle doesn't pump on the proper time of the stroke. It is like it is pumping on the backstroke.How do I get the proper timing back
Hi Donald
Not knowing the details of your pump I can only start by asking one question....
Is it possible to install the new diaphragm upside down?
Reply as a comment to this post to let me know what you find.
Feb 26, 2016 | Solo 475 - 4Gal Backpack Sprayer
My solo backpack sprayer won't pump up when I use the handle. What's wrong and how to repair it?
chabunga offered really good info...except for the suggestion to use Vaseline on the 'O' ring. NEVER use Vaseline on anything rubber, because it is a petroleum based product and it will cause the ring to deteriorate. Use a non-petroleum based lubricant instead.
Jun 03, 2012 | Solo Backpack Sprayer
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Oct 29, 2009 | Stanley Professional Backpack Poly...
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
I have two 428 solo back pack sprayers both of the pumps have crackes in them where do I get parts. Help!!!
i have 428 with a broken pump handle. the solo co. has some parts.their ph. no. is 757-245-4228,i talked to a young man @ ext.352,name is shawnatin.if you can't get the parts,i would like to offer you $5.00 a peice for the handles & shipping cost.just snapped today while working in my yard.
May 02, 2009 | Solo Backpack Sprayer 5 Gallon, Model# 428
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Garden Logo
62 people viewed this question
Top Hudson Garden Experts
ray gallant
Bill Boyd
Steve Cox
Steve Cox
Are you a Hudson Garden Expert? Answer questions, earn points and help others
