Question about Garden
Lawn edger blade won't spin when running - Garden
    Top Expert:
  • Garden Master
  • 47,682 Answers
Shear pin failure or clutch failure
Posted on May 07, 2017
Testimonial: "How to replace the clutch"
How to change blade on mowmaster edger
The bolt that holds it on comes off in the opposite direction as the blade spins.
Dec 20, 2016 | Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Why is the blade on my black and Decker edger spinning backwards and how do I fix this
if its spining backwards the blade is up side down motors dont run backwards they run clock wise your blade should run clockwise to its possible they put your blade on backwards you will hgave to flip it put it back on
May 18, 2014 | Garden
Classic 35 s petrol lawnmower - engine running ok - blades spinning - but not cutting?
It may sound stupid but is the blade on the right way?
Sep 03, 2013 | Garden
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
Sep 26, 2012 | Ryobi Garden
The edger is not cutting very well. Any tips to make it work better?
You said cutting, not running, so I suggest removing the blade and sharpening on a grinder or buying a replacement blade.
I hope you find this very helpful.
Aug 21, 2011 | Black & Decker Le750 Lawn Edger
Replacing belt on troybilt TBE515 edger . After replacing belt blade will not spin when engaged. If i remove the blade the shaft does rotate.
Use a 15/16 open end wrench an correct size allen wrench. Loosen nut (15/16) ccw while holding allen. Geez how dumb are yawl?!
Apr 24, 2010 | Troy Garden
Sears edger blade stops spinning, spins in air fine
check the clucth assamble in the head of the edger it sounds like it is slipping
Aug 16, 2009 | Craftsman Garden
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
