Question about MotorGuide Electrical Supplies
I have a motorguide model 930010390. The manual says to wire for 12 vdc. I just checked and mine is wired for 24 vdc. Will that hurt the motor?
    Top Expert:
  • MotorGuide Master
  • 51,255 Answers
Yes
over voltage burns up motors quickly
Posted on May 07, 2017
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a 767P motorguide that is 12/24 volt. The
Yes and ...no. I'd look for one made for marine use... although any good quality switch will work...for a time. Corrosion will catch up with a :cheapie."
Try these guys... http://www.trollingmotorparts.com/default.aspx/MenuItemID/184/MenuGroup/Home.htm
Good Luck and God Bless, Luckymann77
May 10, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
My 12/24 volt trolling motor only runs on 12 volts
Did you connect 2 batteries to try the 24 volt version? You have to link them together like a flashlight, positive to neg and then out the other side, for 24 volts, like a golf car.
Feb 23, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Have a 56lbs thrust motorguide that is 12/24 volt. it has three wires how do i hook it up to have 24 volt
2 of the wires are line voltage and they share a common nuetral.if they hook to batteries then the common will go to the neg of each battery and the other leads go to the positive terminal
Dec 07, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Nov 05, 2009 | Boating
Electrical Supplies Logo
56 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
