Question about Garden
Lawn edger craftsmen blade won't spin when running?
    Master:
  • 534 Answers
Sounds like something broken in the drive-line.
Posted on May 08, 2017
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
moretons
  • 155 Answers
SOURCE: change the blade
try this site its called pats small engines just look up your model and it will show you a diagram
Posted on Jul 26, 2009
  • 8 Answers
SOURCE: Sears edger blade stops spinning, spins in air fine
check the clucth assamble in the head of the edger it sounds like it is slipping
Posted on Aug 16, 2009
  • 316 Answers
SOURCE: how to change blade on atom turbo 301 lawn edger
hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,~~
Posted on Feb 18, 2012
  • 2239 Answers
SOURCE: blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Posted on Jun 24, 2012
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
What is wrong when craftsmen electric trimmer will not spin
electric trimmers have a problem in the lower bush in the motor . It gets dry from wet grass and wears out and the results in the armature poling out . Mostly unrepairable as the bush is not serviced but check out the spares department as you may be lucky.
Jul 12, 2014 | Garden
Why is the blade on my black and Decker edger spinning backwards and how do I fix this
if its spining backwards the blade is up side down motors dont run backwards they run clock wise your blade should run clockwise to its possible they put your blade on backwards you will hgave to flip it put it back on
May 18, 2014 | Garden
Classic 35 s petrol lawnmower - engine running ok - blades spinning - but not cutting?
It may sound stupid but is the blade on the right way?
Sep 03, 2013 | Garden
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
Sep 26, 2012 | Ryobi Garden
Part
Your part number for the belt is: MTD 954-04032B
You can get a belt fairly cheap by going to this link: http://www.jackssmallengines.com/searchdb_more_info.cfm?part_num=265252&format=searchdb
Feb 10, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
Aug 16, 2009 | Craftsman Garden
How to change an old edger blade
Apr 09, 2009 | Garden
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
