Question about Refrigerators
My chigo wine cooler wc001 is not working properly ,the top temperature is set at 17C. and the bottom part at 10c.the top part reaches reach 20 C the compressor stop .
The bottom part is at 04C. and the heating element do not turn on .Does the compressor stop cause the bottom part get to cold
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
  • 5 Answers
SOURCE: My wine cooler is not reaching the set
check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
hope this helps.
Posted on Sep 28, 2010
Wine cooler keeps going off after a couple of hours
It probably goes off because it has reached the set temperature, it should come back on when it loses temp.
Nov 24, 2013 | CDA FWC600 Wine Cooler
Can I install a thermoelectric wine cooler as a built-in cooler?
No. If a thermoelectric wine cooler were built-in, it would not be able to dispel the heat it emits and the fridge would not be able to reach the necessary temperatures.
Jul 31, 2012 | Furniture
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
What is the right temperature for white wine?
For storage, 10c is fine. For drinking, put it in the fridge at about 4c
Apr 25, 2012 | Refrigerators
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
hope this helps.
Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
