Question about The Audio Players & Recorders
2007 Vizio Gallevia 47" left channel no sound output. Switch around the speakers so I know it's not the speakers.
techman
  • 3130 Answers
SOURCE: Left Channel not working
Not unless youve had solid state trouble shooting experience and experience soldering and unsoldering. If you havent, you should take the unit to a repair shop, as there are no user replaceable parts inside this unit. Your problem is probably the output IC or associated componet. Good Luck
Posted on Jun 26, 2006
SOURCE: Black square on the screen Vizio Gallevia 47" 1080p
Go to menu and Reset all Settings
Posted on Dec 20, 2008
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
  • 3 Answers
SOURCE: Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Posted on Jun 30, 2009
SOURCE: Hi, My Vizio Gallevia 42 is showing a
My Vizio Gallevia 42 is showing a "no signal" message and then shutting itself off. Do you know what that means
Posted on Dec 24, 2009
VSX-4800 receiver. Why is there no left channel audio output?
It is likely that the left channel output stage has failed but there can be problems with that A + B speaker switching. A defective switch can cut output.
Nov 08, 2015 | Pioneer Audio Players & Recorders
Buzzing from speakers
Audio output card has damaged. Replace it.
Oct 11, 2012 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
I have a 42 inch Gallevia model GV 42L. When TV is initially turned on blue screen comes up for about 2 seconds, it then goes black and a screeching noise comes through both speakers on the TV. No...
The power source has failed - the sound is the source that autooscillates because even its protections have been damaged and are no longer capable of safely shut it down.
It's a big failure so call a repairman, ther's nothing more you can do.
Aug 31, 2010 | Vizio SV470XVT 47 in. LCD TV
Hi, My Vizio Gallevia 42 is showing a "no signal" message and then shutting itself off. Do you know what that means?
Dec 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Older person cannot handle two remotes
You can program most satelite remotes to work on any device. Most are universal. If not, I suggest purchasing a universal remote. You can view remote codes online to program your device to your remote. New ones come with instrucions and codes.
Let me know how I can further assist you if necessary
Aug 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Jun 20, 2009 | Vizio VX37L Television
How do I connect my Vizio 42' Gallevia to my DVD home entertainment center? I want it to play through my speaker system. I have tried the analog and the optical outputs but still get nothing. The only...
First check does home theater system has any audio input at rear? If yes, hooke up monitor audio out / tv audio out cable there to have TV sound through sound system by selecting that input.
Jan 03, 2009 | Televison & Video
Channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Jun 19, 2006 | Logitech Z-680 Computer Speakers
18 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
