Question about Water Garden
Nozzle leaking on my h120 power washer. between the nozzle and wand water started spraying out when i was trying to adjust the flow!
SOURCE: problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Posted on Nov 20, 2008
SOURCE: Starbuck's Barista steam wand leak
remove the cover from the machine, loosen the allen screw that fastens the steam knob to the shaft, move it slightly and retighten to allow the knob to close the valve a bit more. I have had to do this a few times in the 9 years I've had my machine as either the knob loosens or the valve threads wear a bit.
Posted on Mar 03, 2009
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 1114 Answers
SOURCE: Pressure washer - no water flow
Is there a check valve on the hose inlet that is stuck, and won't let the water in???????
Posted on Jul 08, 2009
  • 691 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Pressure wand is leaking at the out let end, and pump has a small surge when setting at a idle
Sounds like water is leaking past the shutoff valve on the wand. Check your owners manual parts diagram to see if there is a washer or o-ring to replace.
Apr 16, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Generac 6hp pressure washer starts and runs fine, no real leaks, but it never builds up pressure.
after making the water connections, be sure to hold the trigger open on the wand for a couple of minutes before starting. All the air must be removed from the system before it can create pressure.
Aug 28, 2013 | Briggs & Stratton Pressure Washer...
Troy bilt pressure washer 2550 psi 6.25 hp. we borrowed from my brother and it doesn't have full pressure coming from the nozzle because there is water steadily coming out of the side from a sun shaped...
There is a valve installed to release water out of the system if water temp. rises to a level that may damage the pump. Water temp will rise when motor is running and you are not spraying water. This part is called a thermal valve. It can begin to leak water if worn out or debris under seat, however may not effect a lower pressure at the wand unless it leaks more water when you are spraying than when in bypass. You can see various thermal valves by searching on ebay with the key words :
"pressure washer thermal valve". Pressure is created at the tip of the wand. If the nozzle at the wand is worn or too large for the system, pressure will be reduced. You can check if the tip is correct by using a different tip that came with your system or using new of correct gpm as noted on the specs. of your system. Good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
I have a Troy Built GVC 160 (2600 psi) pressure washer. I used yesterday afternoon without problem. Today, I can get it started, but it conks out immediately as soon as I engage the wand. I'd...
Make sure that the engine is set to full power. Lower the pressure to the unit with the pressure adjust knob as much as possible. Check the nozzle to make sure that no debris has entered and is lodged at the tip of the wand. Start the engine with the spray gun handle in the open /on position allowing water to flow thru. Allow the engine to run for a while to warm-up. Increase the pressure a small amount at a time to reach the desired pressure. To increase the life of the unit, do not use the machine at max. pressure setting. Adjust to about 75% of rated capacity and increase only for stubborn debris then reduce. Good luck
May 27, 2011 | Garden
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
Briggs and Stratton pressure washer will not spray water. The engine is fine but water does not flow.
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Jan 30, 2010 | Briggs & Stratton Pressure Washer...
Can get no water flowing to the spray nozzle
Most likly the sliding nozzle valve is not fully down or up. I have found after the nozzle lay about for some time they get stuck from water scale. It took two persons pulling and pushing on the valve to get my to operate again. It worked for me.
Jun 11, 2009 | Briggs & Stratton Adjustable Spray Nozzle...
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Garden Logo
24 people viewed this question
Top Water Garden Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Don Eagan
Are you a Water Garden Expert? Answer questions, earn points and help others
