My new world DW60 is not allowing the door to close and none of the wash options are lighting up
SOURCE: new world DW60-flashing lights
This dishwasher uses the program lights a s a fault code. Usually it is due to food jamming the impeller. If you are competent you can get at it from underneath. Mine was under warranty when this happened and the engineer was heard to say, 'this is a dishwasher not a waste disposal'. The engineer cleared it with a wire coat hanger down the drian hole inside the machine. Not happened since we really scape off plates.
Posted on Nov 01, 2007
IFIXALL
  • 868 Answers
SOURCE: New World DW60 dishwasher not
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
  • 827 Answers
SOURCE: the new world dw60 dishwasher
either you have a plugged drain or drain filter or the water may not be hot enough in the washer. If you still have a copy of the owners manual it will also give you further solutions to this problem. If you do not have the owners manual go to the mfgr's website and download copy or call cust service...
Best regards
Ck
Posted on Feb 16, 2011
caroldon
  • 17130 Answers
SOURCE: whirlpool awm 6120 door open
Possible that the switch is faulty and so the contacts are open which feeds the signal and the processor take it as an error to stall the functioning of the machine.
So use a multimeter to confirm the ON/OFF switching contacts and replace.
If not there are errors in the controller unit.
Posted on Aug 20, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: panel lights shut off when door closed. Have to set before shutting door is this normal?
    Hello Pat Braley - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
    Posted on Dec 14, 2012
    Can you open the door to begin wash cycle and then close which will allow you to mount flush with cabinets?
    Actually, I think it is designed to do that - select your wash cycle and options with the door open, then press Start, and then close the door within 3 seconds and it should run.
    Dec 13, 2014 | KitchenAid KDTE204DWH Architect II Superba...
    Ge dish washer just installed. First run. All lights working but cycle will not start. Error beeps indicate door not closed but it is.
    That is exactly what the problem is. There is a switch on the door latch, it is not showing the door is latched. Could be bad switch, loose hardware or not connected,
    Jul 08, 2017 | GE GDF570SGFBB Fully Console Dishwasher...
    The new world dw60 dishwasher goes through the wash programme but on completion the dishes are still not clean we do even rinse all the dishes before we put in the dishwasher but still the dishes are not...
    Best regards
    Ck
    Feb 16, 2011 | Dishwashers
    Frigidaire affinity door will not lock when door is closed or register door is not closed when open
    Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
    Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
    Same thing happened today
    with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
    or it could be a blown fuse inside the dishwasher. are any lights on at all?
    Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
    New world wd60
    i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
    Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
    New World DW60 dishwasher not working originally had E4 fault Power comes into the PCB the switches and led's light up but nothing happens. After about 5 mins there is a short beep. Does not show any...
    Jun 23, 2008 | Dishwashers
    Zanussi ZWF1437W washing machine - wont start
    The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
    Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
    New world DW60-flashing lights
    Oct 20, 2007 | Stoves 27 in. DW60 Built-in Dishwasher
    Washing Machines Logo
    35 people viewed this question
    Top Washing Machines Experts
