Question about Mantis Garden
I just purchased a new 4 cycle mantis tiller- assembly was simple but when I followed the instructions on how to start, the fuel bulb never filled with fuel and it will not start. Any suggestions?
SOURCE: My 2 stroke mantis tiller will not fuel
I had the same problem, get a rebuild kit. It sounds like the diaphram is shot. Also make sure the prime bulb doesn't have any holes or cracks, the engine won't run if it does
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: Mantis tiller no fuel getting through to the
the fuel line may be clogged or is collapsed go to a car or a home improvement store go to lawn and garden and get a 3-4 mm gas line
Posted on Apr 23, 2009
  • 45 Answers
SOURCE: 2 cycle mantis tiller leaks gas thru the carb. -
if it leaks gas,it can **** have to find out whats leaking and stop it.
Posted on Apr 29, 2009
  • 376 Answers
SOURCE: Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
Posted on May 23, 2009
  • 376 Answers
SOURCE: mantis tiller sv-4 echo engine no spark from coil
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Prime bulb should it be full of fuel on mantis tiller
No it don't have to be, mine does not fill completely. I have a trimmer that never has anything in it but it runs great. Good luck!
Jun 10, 2014 | Mantis 2-Cycle Tiller
Vapor lock on Mantis
check the fuel lines for a breakage or the primer bulb for a crack. Sounds like it is sucking air instead of fuel
Jan 06, 2013 | Mantis 2-Cycle Tiller
Cannot fill primer on mantis tiller
Check valve in primer body stuck with debris, cannot clean, buy replacement
May 23, 2012 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
We purchased a mantis 2 cycle garden tiller new and have only used it 3 times. it has only been used maybe 1 hour total and now it wont start at all. what can we do to get it to start?
Empty mantis fuel tank. Remove and check spark plug. Replace with Champion CJ8Y or NGK BPM7Y if necessary. Gap is .6mm - .7mm or .024" - .028". Prepare fresh fuel/oil mixture. Add fresh fuel to tank along with 2 ounces of 100% acetone (available at walmart) - this will remove deposits inside of mantis from sitting for prolonged periods. Try to start several times. If unsuccessful let mantis sit for a while. Do this several times if necessary. Eventually it will try to start. If it will not remain started then you are successful in completing the previous section. Next you need to watch this video and do what it says. It is actually quite simple.
Feb 04, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
Mantis tiller no fuel getting through to the primer bulb
Apr 23, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Garden Logo
Top Mantis Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
