Question about Cell Phones
Phone nuber pleas from brlla - Cell Phones
I Ned my home phone nuber. Phone its on name of my partner Cathy D Blasio. I not remember my home number
No one can help you with that query. Your phone number is on the phone bill.
Feb 08, 2017 | Lands Phones
My nokia 5310 died after flashing
try to flash again, with another firmware version or same, because this happen when battery charge is low during flash. that kill mobile. so do it again, if problem persist try to press *+3+green button+power on button hold pressed up to say insert sim. if problem persist that mean you need give some repairer to full flash with flashing box.
Jun 21, 2012 | Nokia 5310 Cellular Phone
Sir, my problem is that when i am on my mobile phone the massage is shone "pleas type the restriction code" so pleas give me solution of this problem. pleas.......
For this problem you can get the unlock code for your Nokia mobile,
you can visit this site http://www.mobileunlocksolutions.com/nokia/rs1wp8/
It has the best instructions and easy methods for unlocking mobile phones...
Nov 08, 2010 | Nokia 6270 Cellular Phone
I need a pin nuber plz
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Nov 08, 2009 | Alcatel Virgin Mobile ?£30 Text Cellular...
I need to block 1-800 phone nubers from calling
That cannot be done unless you block incoming calls all together. Or you can change your number. Have you tried the national do not call list?
May 22, 2009 | Lands Phones
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
May 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
