Question about Microwave Ovens
Microwave showing error code F9Q - Microwave Ovens
Panasonic microwave nn-e252w is showing error code 888. What is the code please, and how do I fix it?
There is no error code 888.
All error codes on this machine start with the letter H.
Dec 14, 2017 | Panasonic Microwave Ovens
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
Nov 05, 2017 | Kenmore Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
Thank you for your inquiry, Leanne!
From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
Apr 27, 2015 | Electrolux Microwave Ovens
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
Sep 11, 2014 | Kenmore Microwave Ovens
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
