Question about Cameras
Where I can purchase a new model as my original has broken ,the tab inside that holds the battery broke off.
SOURCE: sentry s3877 battery compartment broke
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me mark@irregardless.net.
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
Posted on Nov 14, 2008
  • 5 Answers
SOURCE: Broken battery latch cover
no, is not practical to repair. you can do bigger mass what is now. only what you can do is secure cover with self-adhesive tape. if you not satisfied with this, go to service and pay repair.
Posted on Mar 25, 2009
  • 65 Answers
SOURCE: power window cable connection point -broken tab on plastic piece
the regulator has broken.you will need a new one.they do repair kits for golfs and beetles but not for passats you have to replace the whole regulator.dont attempt it unless 100% confident they can be tricky.
Posted on Apr 27, 2009
  • 7 Answers
SOURCE: Vivicam 3650 Broken Battery Door Tab.
WWW.VIVICAN/SUPPORT.COM
Posted on Jul 14, 2009
SOURCE: Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Posted on Feb 25, 2010
HOW TO REPLACE BATTERY REMINGTON RAZOR R-4100
Hi Docle60,
You'll only need a couple of tools and a little time. The steps are pretty easy.
  • Take your electric razor apart to find out what type of replacement battery you need.
  • Buy your replacement batteries.
  • Remove your old batteries
  • Solder the new batteries and place.
  • Reassemble your razor and test it.
There are a couple of ways to buy your replacement batteries.
  • Do a google search using the model number of your razor.
  • Find the original battery model number and search using that
  • Find the original battery voltage and milliamps and search using that information.
Using the model of your razor, you might want to try shavers.com or, If your not good at soldering, purchase pre-tabbed batteries already soldered on them. If your batteries are a standard size, you can purchase them from Amazon at a reasonable price.
Hop this helps
David
Dec 01, 2017 | Remington Health & Beauty
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
My start button doesn't work, very loose, appears to be off track to engage
Had same problem but solution was different. Start button looked slightly misaligned and wouldn't always work. Followed instructions to pull off front control panel, removed LED display panel and the plastic tab that the start button was attached to had broken off from the panel. Used a good epoxy to glue the edges back together and it works like new. Also broke two tabs that hold the LED panel inside the front plate due to the plastic becoming brittle. Again, epoxy is your friend. Works like new. d04211d8-3b3d-44fc-bc8c-6da6cd6ecf7e.jpg
Jul 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • Aug 10, 2010 | Fossil Brown Ip Brown Rectangle Ip FS4284...
    Fe 5020 digital camera plastic tab that holds battery in broke off and now receive an error message that the card cover is open
    The base is working as a complete circuit when it is closed completely. Now as the plastic tab which holds battery is broken so the circuit is not getting completed and the software of your camera is not getting message that all parts are functioning accurately. You need that plastic tab or similar tab to fix this problem. Please show your camera in a repair shop and they will get it fixed at very low prize as they normally have such parts with them.
    May 29, 2010 | Olympus FE-140 Digital Camera
    Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
    Bottom oven heating element turned white hot and broke in the middle. Can I replace myself?
    This is a common problem and easy repair. Locate the model number onside the oven door frame. Purchase the element based on the model number. TURN OFF the power to the oven. Unscrew the 2 screws inside the oven holding the element to the back wall. Gently pull the element forward. The wires will be short.Remove the wires from the broken element. Place them on the new element. Re-insert the element terminals and attach the screws.
    TURN ON the power. Bake me some cookies and send them to me.
    Jul 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
    Sentry s3877 battery compartment broke
    ---- Mark
    Sep 15, 2008 | Sentry Fireproof Safe
    Battery door wont stay on
    get some tacky stuff... gum maybe.
    i have the same problem... it sux i agree but not much can be done without glueing it on permanently.
    that or use the phone insurance...
    my screen just broke too so i'm awaiting the new part to come in for around $55... beats the hell out of 110 for the insurance to fix it!
    Aug 07, 2008 | T-Mobile Wing™ Smartphone
    Cameras Logo
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
