Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
My external is WDigital 160gb
I groping in the floor, now i cannot open it,please tell me how to do? IT is very new ............help me
  • Bruce Kaufman
    Bruce Kaufman May 11, 2010
    did you drop your hard drive? Is it making a sound?
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 23, 2009
    Scholar:
  • 120 Answers
If you dropped it, you probably broke it. The external drives have a shock detector and that will display impact. You probably have no warranty after that, unless you got a comprehensive warranty from Dell, another manufacturer, or a homeowner's policy.
I just upgraded my Windows Vista 64-bit computer to Windows 7 64-bit. Backed up all my documents onto a ST3200823A-RK Seagate external hard drive. I have used this HD for 3 years, and it has always...
if you external hdd does not work on any other computer other than yours . try opening it with a linux OS. u can Ubuntu live cd .. boot from it and run it live...connect your HDD .. i hope you can see you files then >>> good luck
Jun 20, 2011 | Seagate 160GB 3.5" External USB Drive 160...
Hard drive not working
check either the problem is in external case or in the hard drive.
if the problem is in the hard drive then replace it with new one.
Dec 05, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
EXTERNAL HARDDRIVE 160GB
Open the drive and see whats burns, if the case circut is burnt put the driv in a new case. the the harddrive is burnt your out of luck.
Sep 05, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
My simpldrive deluxe external harddrive 160gb doen't power on any more...
Is it a 3.5" or 2.5" drive?
If its a 3.5" the first thing I'd check is the fuse in the plug for the power supply (if you're in the UK)?
If changing the fuse doesn't work it could be a problem with the power pack within the external HDD. Is it under warranty? You my be able to get it repaired or a new one (Don't forget, if you open up the fasia of the hard drive you will void the warranty). I assume you're not worried about data on the drive as you are happy to format it. If you are worried about data and it isn't under warranty/garantee I can tell you how to get the data off if you need me to?
Hope this helps.
Nov 18, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Simpletech hard drive
Your desktop usb compatibility is not supported your 160GB. The only way to attach you 160GB is to make it secondary partition to your primary drive by opening the CPU and attach it to your IDE cable.
Don't force yourself if you cannot do it by yourself just leave it to the expert. Probable cause to damage your hard drive if it is not installed properly.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 29, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
90 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
