Question about Proscan Televison & Video
Hi, I have a proscan TV model#plcd5085a. The picture is not the brightest and on the left side u can barely see anything. It's also making a sizzle sound on the inside. Can u please help me figure out
SOURCE: Proscan PS61700 Beeping no picture
I have a 60in Proscan Projection TV. My picture is out and the TV only beeps.
Brian Allen
Posted on Mar 17, 2008
SOURCE: HOW TO OPERATE PROSCAN REMOTE MODEL CRK76DBL1..
I still have not figured out how to program the exact code in the crk76DBL1.
However, I did figure out how to use the code search for the TV
1) Turn on the component you want to control (TV, VCR, DVD)
2) Press and hold BOTH the component button on the remote and the On-Off button
3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
I hope everyone finds this helpful and saves people time and frustration.
Posted on Jul 04, 2008
SOURCE: unlock apex tv model # AT2702
i need to unlock my tv
Posted on Dec 05, 2008
  • 25 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
SOURCE: 42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
Posted on Jun 03, 2009
Flatscreen tv picture has shrunk to the upper left side of the screen
The TV is in Picture-in-picture mode. The small picture is the last active source. The bigger area is the current source connection, but there's no signal.
Read the manual about how to operate the Picture in Picture feature.
Sep 05, 2014 | Proscan 32LB30QD 32 in. LCD TV
Sony tv troubleshooting
Hi, Please try to push or move the frame of your tv set on the dark side of the picture. If the picture becomes normal it is the loose connection. Otherwise it may be panel failure. Please consult some qualified technician or the service center.
May 04, 2014 | Televison & Video
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
All of a sudden no picture just snow
Do you have a spare TV? Hook it up to the Sat. box. If you still have no picture, then the Sat. system has a problem. If the sub TV does have a picture, then the problem is on the ProScan end.
May 06, 2008 | Proscan PSVR83 VCR
Brian Allen
Feb 03, 2008 | Proscan PS61700 60 in. Rear Projection...
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Televison & Video Logo
24 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
