Question about Samsung HLP4663W 46" Rear Projection HDTV
Tv was working went off LAMP flashing and would not come on.
I called a TV repair person and described what had happened. Let them hear the clicking noise that my set would do when you try to turn it on. Bought a $150 bulb replaced it and now my set is making a horrible loud noise. I have read through countless troubleshooting's and i am lost at what this could be. Could it be the balliste or the color wheel? I dont want to keep throwing money at a tv if i am going to keep trying to have problems. Is there a way to find out for sure what is the problem?
  • 4,234 Answers
Lets go back to the beginning... What were the original symptoms? Was it just the clicking or were the lights on the front of the set flashing too? With the new lamp, is there any thing else other than the clicking? If not, then the problem is likely to be the ballast. The clicking could be the lamp attempting to "fire". With a defective ballast, the lamp won't fire and the set won't come on. If you choose to replace the ballast, DO NOT use the old lamp. It is relatively common for a defective lamp to smoke the ballast under certain conditions. Also, it is possible that the original cause was the ballast that failed and took out the lamp with it.
Please keep us posted.
Thanks,
Dan
Posted on Jul 25, 2009
TV RUNS WELL THEN ALL OF SUDDEN IT TURNS OFF.
Posted on Aug 10, 2009
I have a Samsung Model HCP-P4241w While i was watching tv. I heard a pop and the Tv went black. Now when i turn the tv on the screen is black, But no "Bling" sound comes on and the red light in front of the television blinks. No sound or pictures appear. Thank you for any help out there.
Posted on Aug 06, 2009
Replaced ramp but can not get rid of flashing replace lamp signal every time I now turn on the tv. I tried the vol - & holding split/play button, but it didn't work
Hear many clicks too,after the tv projection lamp "LED" light indication LAMP flashes?Yes,than the board that call the Ballast board require changes too.This Ballast board only job are too help to ignite the tv projection lamp to lit up and work.
May 31, 2011 | Panasonic PT-50DL54 50" Rear Projection...
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Sonykdf-55wf655 had blue shadows tv went black replaced lamp
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Have a blessed one!
Mar 30, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for...
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Sep 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I was watching tv when the screen suddenly went blank. I tried to power off and back on. The power button blinks a red light and nothing happens
The TV has sound, but no picture.
The lamp is the most common part that causes this symptom. If you have purchased a new lamp already, click on the “Signs of Lamp Failure” link below to check your lamp or contact who you purchased your lamp from for a warranty claim. Look at the indicator lights on the front of the TV and use our chart by clicking the link below to find out what error the TV is displaying to help you. If you have not purchased a new lamp, the lamp is the most common and cheapest repair for this symptom. A defective circuit board can also cause this symptom in which you should contact a certified/trained TV technician.
If your lamp shows any of the signs listed below, there is a high probability your lamp is defective.
Find DLP lamps by model number
Common Signs Of Lamp Failure
- Cloud or haze near the center of the lens.
- The burner (the stem in the center of the lamp) is broken
- The burner has a white bump on it (usually near the bottom)
If the lamp does not have any of the characteristics described above, you check by brand below for LED flashing light codes to keep troubleshooting.
Sep 10, 2009 | Panasonic Televison & Video
Panasonic PT-56LCZ70 no picture or sound
My name is Jonathan and I am an employee at the Panasonic Customer Call Center. Based on the symptoms you've described, I'd recommend contacting the Panasonic Customer Call Center at 1-800-211-7262 for assistance. We are here to help customers that have purchased (or are considering purchasing) our products and would like to assist you with resolving the symptoms described here. Our hours of operation are:
Mon - Fri, 9 AM - 9 PM EST
Sat - Sun, 10 AM - 7 PM EST
Dec 11, 2008 | Panasonic PT-56LCZ70 56" HDTV
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
Lamp Light flashing Yellow
double check the lamp.make shure the 2 wires were installed correctly.Also check the plug inside the tv where the lamp plugs in.They have a nasty habbit of coming loose.
Jul 17, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
572 people viewed this question
Henry  Thomas
Henry Thomas
