Question about Android Cell Phones
How can I. Make my s/cam go to my phone by connections to the internet with tab are my direct systems I also have a DVR what one would be better to Mack I go to Mt Android phone
  • 3 Answers
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
Posted on Jul 31, 2009
  • 274 Answers
SOURCE: how do i connect mt h721 to my android phone
Turn on the headset's bluetooth, then use your phone to search the device, and follow the guides, it should work.
electronics wholesale
Posted on Nov 16, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: cant print from android (samsung galaxy tab)
    Lexmark just recently released the Lexmark Mobile Printing Application for use with Android devices, however, the application is supported only on most laser products and the very latest inkjets that are coming out for 2011(the Lexmark Pro715 and the Pro915 are the only models announced at this point.).
    Posted on Nov 29, 2011
    • 18 Answers
    SOURCE: How do I upgrade the Android system on my Samsung Galaxy S Tab 10.1?
    Since you are using the Samsung brand, Samsung controls when they release updates to that device.
    You should be able to search using your favorite search engine to see if your device will be updated, otherwise you can contact Samsung to get more details on any updates.
    Posted on Jul 06, 2016
    rafael_colom
    • 14 Answers
    SOURCE: How to Upgrade the android system on my Samsung Galaxy Tab 2?
    Go to youtube
    Posted on Jul 08, 2016
    I am using my htc android's hotspot to power all of my wifi gadgets in my home. I just bought bunker Hill H.264 DVR security system and am trying to configure it to my phone for remote viewing. Please...
    You need P2P Cloud Setup. DDNS Service will not work.
    no option to port forward in mobile or mobile isp use firewall block users to access connect directly to internet.
    Visit:- https://www.youtube.com/channel/UCxAhv5XWrbpjvdfVBVEHCMA
    Mar 21, 2013 | D-Link Home Security
    I cannot access my internet viewer
    More details are required.
    The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
    The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
    Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
    With minor adjustments..that's it.
    What didn't you do?
    Dec 25, 2012 | Samsung 4 Channel Dvr
    I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
    IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
    • Make: Unknown Brand Model: DVR-9008HV
    • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
    For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
    I hope this helps
    Jul 07, 2012 | Apple iPhone 3G
    What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
    Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
    As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
    The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
    Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
    We switched from cox Cable to Direct TV. The BD390 works normally through an Apple Airport Express with an Ethernet connection to a Motorola SB 6120 modem. The system does everything it is supposed to...
    So practically you want to use the BR390 as an access point, to route the data from the Apple to the DVR. No, this isn't possible since the player doesn't have routing capabilities.
    But you can do something else: instead of the Apple (which is just a very simple router with some minor extra capabilities sold ad an outrageous price) you could get a way better normal router for a lot less than $100 and connect all devices thru LAN cables in an local network.
    Aug 17, 2010 | LG BD390 Blu-Ray Player
    Trying to connect Archs DVR snap on to LCD TV and record
    As far as i am aware you cannot record directly from the tv using a dvr snap on to record from the tv you would need the dvr station.
    Dec 28, 2009 | Archos 5 Internet Media Tablet
    How to setup up my cctv cam to sonicwall tz170
    If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
    Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
    Internet connection to DVR fails with error
    Any one interested in a class action against Q-See for lack of support even though this is one of the selling points?
    Aug 27, 2009 | Internet Q See Ufo CCD Camera
    Cant access lorex DVR from the internet
    u need a public ip with an open port, and portforward the port with the ip of ur dvr
    Mar 15, 2009 | Home Security
    No signal
    how do i connect a usb stick for a ch usb dvr to a video player
    Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
    Cell Phones Logo
    Top Android Cell Phones Experts
    Owen Barnes
    Ron Durham
    Are you an Android Cell Phone Expert? Answer questions, earn points and help others
