Question about Troy Garden
How to replace pull rope on Troy bilt bronco tiller
landsend
  • 1066 Answers
SOURCE: I just purchased a troy
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Posted on Mar 29, 2009
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
Posted on Aug 06, 2009
  • 468 Answers
SOURCE: Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Posted on Feb 01, 2010
al_kupchella
  • 843 Answers
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Jun 15, 2010
tunde007
  • 2382 Answers
SOURCE: How do I replace the
Hi, you must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Posted on Sep 06, 2010
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
What motor oil does the troy bilt bronco use
10w-30 should work.it should say what oil to use on it
May 27, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Bought a new part to hold the starter cord for my tiller
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope through from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 01, 2009 | Troy-Bilt Garden
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
May 19, 2009 | Troy-Bilt Pony Garden Tiller
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
46 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
