Question about Cell Phones
My phone says In Airplane mode, but replacing SIM card did not help?
I have a refurbished tracfone-ZTE Model# Z716BL. We tried master reset on many occasions and new SIM card. The phone still comes back with a "turn off airplane mode when trying to make a call.
    New Friend:
  • 3 Answers
You just have to go to sertings and turn off airplane mode.
Posted on May 08, 2017
Nextelneo
  • 133 Answers
SOURCE: Airplane mode
Sounds like your phone is damaged .. your best bet is to take it to a service center for repair
Posted on Dec 05, 2007
SOURCE: airplane mode
I have found that if you press and hold the power key when turning on the phone, it can activate the airplane mode. Try to press and release it when turning it on to stop this problem.
Posted on Jul 10, 2008
Gyrxiur
  • 79 Answers
SOURCE: Touch diamond stuck in airplane mode, gwes error
try updating your ROM, you find everything on HTC website in support section
Posted on Jul 11, 2009
ashlocked
  • 1140 Answers
SOURCE: purchased a phone from flee
if you want to use ist by-land... switch of airplane mode...
Posted on May 29, 2011
  • 63 Answers
SOURCE: I have droid phone. Says
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Posted on Sep 26, 2011
ZTE projector needs a factory reset how can I fix this problem
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Device resets ZTE ZMAX
Feb 12, 2018 | ZTE Cell Phones
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Hope this helps!
Nov 01, 2017 | ZTE Cell Phones
How do I fix that I ain't able to make out going calls on my ZTE N8ยน7
> Make sure you have de-activated "Airplane mode"
> Make sure you have enabled the SIM card if there is a setting for that.
> Make sure you have a valid SIM card in your phone and the SIM card is accepted by phone and is working.
> Make sure you have network coverage.
> Make sure you have enough credit on your SIM card to make a call(If pre-paid).
If all above are good, you'll be able to make a GSM call
Jun 12, 2017 | ZTE Cell Phones
Need to know how I order a sim card for my cell phone
Hi there!
The ZTE Z717VL Citrine LTE is specifically manufactured for Tracfone services. You'll need yo contact your service provider to get the SIM card even if you contact ZTE they'll redirect you to the service provider.
Apr 08, 2017 | ZTE Cell Phones
Sim card not detected,number and carrier unknown on zte tracfone,can i just buy new sim and sd card?
A lot of tracfone handsets have no sim card at all. Call Tracfone or go online with them to get a resolution to your problem.
Dec 13, 2016 | ZTE Cell Phones
I got the phone from a friend, did a factory reset. then turned it off and plugged in my T-Mobile sim card then restarted it. it picked up my sim card and contacts but will not let me call, no signal.
It may not be compatible with you sim. If you have t mobile as your carrier then it won't work with tracfones. the IMEI is set to tracfones network and not on t-mobile's networks. You could have your friend call tracfone and see it they will unlock the phone. As long as your friend had complied with there terms of service they might unlock it for him. Then you should be able to use it on t-mobile's network. Also check your apn settings.
Oct 17, 2015 | Tracfone Wireless ZTE Valet
My optimus exceed 2 will not allow me to make phone calls or send text messages. When I try to do so a window appears saying that the phone has no sim card or the phone is on airplane mode. It is not on...
first try this Code *#06# and check IMEI number if nothing problem with IMEI than reset your phone if till not solve than its Hardware problem from Sim IC OR Simtray
Aug 03, 2014 | Cell Phones
Zte instructions
Hello John/Felicia Hamilton,
There are a multitude of scenarios that can cause your phone to "lose service". I have found that the most productive way to restore cellphone service to you device is to simply go into your setting, set your device into "airplane mode", count to 20, and turn airplane mode off.
If this does not work, attempt to remove your sin card (Only if it is easily accessible, if it isn't then please do not disturb your Sim and cause any further damage.) Once the Sim is removed, count to 10, and reinsert it.
If neither of these work, then your SIM card reader could be malfunctioning, and is no longer able to render your sim. Or, your SIM card is worn and no longer able to render your service.
Thanks,
Dish Guy
May 17, 2014 | Cell Phones
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
ZTE PHONE UNLOCK
How to unlock ZTE z665c for emergency call
Aug 06, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
103 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
