Question about Canon Office Equipment & Supplies
In canon mp250 the on button blink 2 times and then the alarm light keep on what is the problem??
SOURCE: canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
I just helped my daughter fix hers by following these instructions I found elsewhere - it worked. Make sure you wait until the light stops blinking to push 'reset' 4 times. Also - lots of people reported small objects obstructing the cartridge - make sure that is not the case first.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Jan 07, 2009
  • 412 Answers
SOURCE: my canon pixma mp140 error 2 and the alarm light
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Mar 09, 2009
pineworks
  • 4041 Answers
SOURCE: Canon Pixma MX300 - error code 5B00 - check
Try it works for most Canon
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Posted on Jan 25, 2010
  • 232 Answers
SOURCE: Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Posted on Apr 07, 2010
pheireith244
  • 310 Answers
SOURCE: My canon pixma mp495 has
Press Stop/Reset button for five second. After all your printer will start working.... thanks....
Posted on Aug 22, 2011
Canon mp250 flashing power, alarm, ink LED P 1 0
Have you tried unplugging it and plugging it in again?
Nov 16, 2013 | Canon MP250
My canon mp250 is showing a E16 error and has the alarm constant orange and the B blinking. I tried removing and replacing the cartridges but it did not help. I cannot scan either.
Error No. E16 is caused by Ink has run out / cartridge must be reset.
To solve the problem here is your solution:
Press the STOP / Reset for 5 - 15 seconds wait until the led display process.
Aug 22, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I just bought a Canon MP250 scanner, printer copier. I printed 1 page and after that the on button keeps flashing, the letter P and number 3 keeps flashing next to the on button. Also an amber colored...
The manual says: " 'P, 0, 3' is displayed: If any object is placed in front of the machine, remove it. Open the Paper Output Tray gently, then turn the power off and back on."
If this doesnt work you need to contact the canon service center, you can find all of the information on their Webpage
Aug 21, 2011 | Office Equipment & Supplies
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a Canon Pixma MP250 this is the third one I have owned. Every time I get the same error. It says a paper is jammed when there is no paper in it. I really like this printer when it works. The last...
They are great printers once you learn this reset technique.
Try this first. By resetting the EEPROM, you may be able to clear the alarm and resume printing. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code. This is a cheap printer and it is EASILY FOOLED by it's own internal software. I had to send a brand new one right back to the manufacturer because it was already throwing a fake code when it was first unwrapped.
Jan 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp250, not printing. Print screen says "creating print data" and freezes there.
This sounds like an internal memory problem and I don't have a workaround. Before you give up, try this technique to reset the printer to factory. They are great printers once you learn this reset technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 20, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do i clear an error 5100 from my canon pixma mp250?
Try this technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 14, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
29 people viewed this question
old marine
old marine
