Question about Miller Welding Tools
Need control plate for miller welding machine trail blazer 55 d seril no.298428
jyackle5
  • 8197 Answers
SOURCE: Need operating instructions for Thermal Arc 190 GTS tig welder
Try this one if not it go to the next link for manuals.
http://www.thermadyne.com/IM_Uploads/DocLib_2143_300X4838.pdf
http://www.thermadyne.com/thermalarc/component/option,com_doclib/task,/id,/Itemid,237/categoryID,4/
Posted on Apr 06, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
  • 87 Answers
SOURCE: Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Posted on Oct 20, 2009
Testimonial: "appreciate the help."
mxtras
  • 194 Answers
SOURCE: I have a miller microwave 200. what settings
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Posted on Jan 12, 2010
  • 81 Answers
SOURCE: Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Posted on Jul 20, 2010
Miller welder
Unfortunately, since this machine is CV (constant voltage) it is strictly for Mig or Flux-cored welding. Anything that is stick welded can be welded with Mig. All you need is a compatible Mig welder.
CP 302 MIG Welder MillerWelds
Nov 11, 2017 | Miller Welding Tools
Where do i need to look for serial number on older modle miller wildcat 350 d
The serial number on an older 350D should be on the face plate either on a tag or punched in on the faceplate, sometimes near the bottom of faceplate. If there is no serial number there, you can call Miller with the engine type, engine serial number and they might be able to trace the machine number down. Other that, you can get a general span of number by matching up schematics with your machine. Manuals Parts
Oct 21, 2017 | Miller Welding Tools
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
I am getting holes appearing when I stop welding. There is nothing wrong with the gas (pressure/post/preflow checked) as i have checked it all out. I have put a new torch on and a new regulator but it has...
Wow what a great machine. You have so many options that you should be able to control the ending arc. Yes, you should be able to adjust the intensity of the HF. Also if you use the Sequencer Control, you should be able to finish the weld in a slope manner. I am including the owners manual. Operation starts on page 38. Miller has a team of welding engineer that will be able to help you set up your machine. Wish I had one.
Oct 04, 2017 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
Oct 20, 2009 | Welding Tools
301 wont high idle when striking arc
There is a small electronic control board inside the welder that senses current flow and pulls up throttle. It could be the board has a problem, or the throttle solenoid itself. You'll have to do a bit of checking.Check for loose connections or blackened components on the control board.
Jul 03, 2009 | Welding Tools
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Welding Tools Logo
82 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
