Question about Pool & Spa
Sand filter keeps blowing sand back in pool. What could be the problem?
    Top Expert:
  • Pool & Spa Master
  • 7,401 Answers
Bad laterals replace or replace filter
Posted on Sep 13, 2017
  • 52 Answers
SOURCE: There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Posted on Mar 02, 2009
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
  • 19 Answers
SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Posted on Apr 30, 2009
  • 93 Answers
SOURCE: filter is shooting sand back into the water when
Posted on Jun 19, 2009
  • 17 Answers
SOURCE: Sand Leaking From Filter into
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Posted on Jun 16, 2011
Can the filter blow sand into the pool?
If you are using a sand filter and if the plumbing is incorrect you can flush sand into the pool instead of flushing dirt down the drain. If you are using a sand filter and the sand support screen material is torn you can get sand into the pool.
Dec 05, 2014 | Pool & Spa
How do you know if your hayward s 200 is not running right
sand in your pool is a sign that you may have damage inside your sand filter. it is not uncommon for laterals to break during winter months. also, as the sand wears, it becomes smaller and may pass through.
remember that the filter sand is white. if you have sand in the pool that doesnt look like filter sand, you may have a problem with a broken line back to pool. keep an eye on your water level as you will lose water with this scenario
May 07, 2014 | Hayward Pool & Spa
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
When backwashing...sand discharges out backwash hose..
A little sand in backwash is not uncommon. Many packaged sand filter systems use pumps whose flow rates greatly exceed the flow capacity of the filter.(the more horsepower the better, right? - Wrong) If this occurs only during back flush the the pump is too strong or the sand level is above the beginning of the rounded top of tank. The sand level will eventually correct itself.
Aug 10, 2012 | Hayward SAND FILTER, PRO SERIES
I just finished cleaning my pool when I noticed debris around the area where my inground pool jets are. So I backwashed and vacuum that area. However, once in filter mode I noticed sand at the bottom of...
When sand comes back from the filter, that means that the device inside the filter that keeps the sand in has broken. In order to replace the item, all of the sand must be removed and the tubes must be removed and new ones installed. Go to your local pool supply house with your filter information and they can show you how to remove your old units and they will sell you new ones. You only have to replace the ones that are broken.
Aug 12, 2011 | Hayward SAND FILTER, PRO SERIES
When I was filtering the pool the sand from the sand filter is blowing sand into the pool
That means that you have a cracked lateral in your pool filter. You will need to replace the lateral, which should stop the sand from entering your pool through the return line.
Jul 10, 2011 | Hayward SAND FILTER, PRO SERIES
Blowing sand into the pool
If your pool filters blowing sand into the pool, it means that you have a broken or cracker lateral. You will need to have the lateral replaced and it should eliminate the problem.
I have an Hayward Pro Series S244T filter and I have had problems with sand blowing back into pool - the filter is only 2 years old
When sand returns to the pool, there is a hole in either the media or the sieve that is supposed to keep the sand in the filter.
All of the sand must come out of the filter, the sieve at the bottom (outlet of the filter) must be removed and any broken segments must be replaced.
The sand is then returned.
Apr 27, 2011 | Hayward SAND FILTER, PRO SERIES
I have a S21OT sand filter that is running off the pressure guage and flowing sand back into the pool. The laterals are fine, I changed the sand, backwashed for about two minutes, and rinsed, The pressure...
Usually sand blowing back into the pool is either cracked laterals, a cracked hub assembly (what the laterals screw into) or a bad spider gasket is wrong with pool filters. If you are certain that the laterals and hub are not cracked then I would try replacing the spider gasket.
Apr 08, 2011 | Hayward SAND FILTER, PRO SERIES
Mar 01, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
37 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
