Question about Yamaha Office Equipment & Supplies
Yamaha DPX830 projector, couldn't get the cover off to change the lamp
5 Suggested Answers
SOURCE: Lamp/Cover Error
I had the same problem with a "Sony VPL-ES3" projector. The lamp cover light would flash and the projector wouldn't turn on.
I think its a problem with a filter cover. This fixed the problem for me:
  1. Plug out the projector
  2. Click off the filter at the bottom of the projector.
  3. Plug the projector back in. (the lamp cover light should flash)
  4. Plug the projector out again.
  5. Put the filter cover back on.
  6. Plug the projector in again and it should work fine.
This has worked for me every time I have had this problem.
Posted on May 23, 2008
busgeek79
  • 36 Answers
SOURCE: Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Posted on Jun 30, 2008
  • 5 Answers
SOURCE: When the SONY VPL - ES1 projector is turned, the
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Posted on Aug 04, 2009
lbrown1806
  • 488 Answers
SOURCE: how do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Posted on Apr 12, 2012
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | Dell 4310WX Projector
How do I change my projector lamp?
Instructions
  1. Front Projector
    Rear Projector
    • 10
Tips & Warnings
Apr 11, 2012 | Office Equipment & Supplies
How do you install new light bulb
The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
  1. Switch off the power to the projector by pressing the Power/Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use the screwdriver to remove the screw from the cover. (1)
  5. Push up and remove the cover. (2)
  6. Remove the 2 screws from the lamp module. (3)
  7. Pull out the lamp module. (4)
To Replace the lamp module, reverse the previous steps,
Feb 28, 2011 | Optoma EP716 Multimedia Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
How do I change the lamp on a NEC NP510 projector? If I open it up it voids the warranty...
The lamp is a consumable item and is not covered by warranties of any kind. The cover for the lamp should not be sealed. If it is contact your supplier for advice.
Jan 20, 2011 | NEC NP510 Projector Projector
How to change the bulb?
hi,
do the following steps to change the lamp of your projector.
1. Turn the power off and disconnect the projector from the wall socket.
2. Turn the projector over. Then loosen the screws and remove the lamp cover. If the lamp is hot, avoid burns by waiting for 45 minutes until the lamp has cooled.
3. Move the latch to another end as shown in the picture.
4. Loosen the screw that holds the lamp to the projector. If the screw is not loosened
completely, they could injure your fingers. It is strongly recommended that you use a
magnetic-head screwdriver.
5. Lift the handle so that it stands up. Use the handle to slowly pull the lamp out of the projector.
6. Insert a new lamp. Make sure the handle is fully locked, move the latch back, and
tighten the screw firmly.
7. Re-install the lamp cover and tighten the screw. Do not turn the power on with the lamp cover removed. Whenever the lamp is replaced, reset the total lamp operation time. Do not reset if the lamp is not replaced as this could cause damage.
8. Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
ok
Jan 19, 2011 | BenQ PB6110 Multimedia Projector
How do you change the bulb?
Hello :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
Here are the steps that explained in the manual :
Lamp Replacement Procedure:
2. Allow the projector to cool down for at least 30 minutes.
4. Use a screwdriver to remove the screws from the cover.
PLEASE RATE !
Apr 13, 2010 | Optoma EP747 Multimedia Projector
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Top Yamaha Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
ray gallant
Are you a Yamaha Office Equipment and Supply Expert? Answer questions, earn points and help others
