We can't get the cover off to change the lamp using the manual. Can you help?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
? smash it.
Describe the problem
-type of equipment
-use
-perhaps a picture
Question cant be solved.
Posted on May 07, 2017
How do you open the sewing head to change bulb on Pfaff 955 hobbymatic
To access the light bulb, use the button-hole foot to lift up the insert on the arm cover. Remove the cover. Hold the edge guide slightly tilted and push it into the opening in the head of the sewing machine. Press down on the lamp housing to hold it still. Push up on the bulb and turn it counter-clockwise. Once the bulb is loose, pull it down and out of the lamp housing. To replace the bulb, continue to hold the lamp housing. Push the new bulb into the housing and rotate it clockwise. Release the lamp housing and then use the button-hole foot to replace the cover.
Pfaff has the manuals for most of their machines here: http://www.pfaff.com/en-US/Support-and-Updates/Support . The Hobbymatic 955 support page is http://www.pfaff.com/en-US/Support/3529 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Pfaff_935_955_HobbyMATIC-manual-EN-FR-DE-NL.PDF . See page 51 (page 59 of the PDF) for the directions to change the light bulb, These pictures may help you see how to get to the bulb. If you need a replacement button-hole foot, see http://www.sewingpartsonline.com/buttonhole-foot-low-shank-new-1932l.aspx .
I hope this helps.
Jul 21, 2017 | PfaFF Sewing Machines
Sharp projection tv lamp replacement
Rear Projection Televisions are not like other televisions that can run maintenance-free for 20 years or more. They need to have their lamps changed on occasion, and most have air filters that need to be cleaned every month or two. Lamps typically last about 8,000 hours on most models high end models, some of the cheaper models last only 1,000-2,000 hours. Keep in mind however that some lamps won't make it all the way to their estimated life spans. If you operate your LCD or DLP TV in a warm environment that is not adequately ventilated, or at higher elevations, this can reduce lamp life. Failing to keep the air filter clean may reduce lamp life as well. And some lamps will just fail sooner than others--estimating average lamp life is not an exact science and testing methods vary greatly among manufacturers.
ere is a checklist of what to do to get the most out of your lamp:
  1. Check out the presets and select the setting with the lowest light output.
  2. Once you've done that adjust the brightness down to your liking. The lower the brightness the long the lamp will last.
  3. Check and clean the air filters on a monthly basis. Having a clean air filters means that your lamp has better airflow. Air is what is used to cool the lamp and the cooler your lamp runs the longer it will last.
Each owner's manual for a rear projection TV comes with instructions on how to replace the lamp. Here are the typical steps for replacing a lamp.
  1. Turn your TV off. Let it sit there for about 5 minutes to let the cooling fan help cool the lamp.
  2. Unplug your TV from the power let it sit about another 30 minutes. Even with the TV turned off power is still going to the lamp and the lamp receptacle can still be hot enough to burn you. Even if you think that the lamp is cool I recommend that you do not touch the receptacle.
  3. Usually the lamp has a cover that you will need to unscrew. Most manufactures use a Philips head screw for holding the cover shut. Unscrew the lamp cover.
  4. Unpackage the replacement lamp. Be careful not to tough the glass, as oil from your fingers can damage the lamp's surface.
  5. Pull the lamp out. Most lamps have a plastic tab or hoop on the handle that you can use to pull it out. Follow the owners manual for specific instructions on how to pull the lamp out. Make sure you do not touch the surrounding lamp housing if you just turned off the TV. It can burn you if it is hot.
  6. After the lamp has cooled, place it into the empty box of the replacement lamp. Never put the used lamp into a plastic bag.
  7. Using the guiding post also called "gutters" by some manufactures slide the lamp replacement lamp in pushing it until you hear a firm click.
  8. Screw the lamp cover back in.
Dec 23, 2007 | Televison & Video
How to change the fluorescent bulbs
Most fridges use either a friction tab or or gravity to secure the translucent plastic window cover on the inside over the lamp. The owner's manual should provide detailed instructions. Avoid using a plain screwdriver for prying, as hard plastic often cracks or breaks at the tabs. For gravity held covers, simply slide the cover upwards to detach it and then pull gently outwards to release it. Unplug the fridge when changing the bulb and use a 40 Watt lamp especially made for refrigerators. Do not get confused at the store and buy the one marked "Oven" as they look the same from the outside. Many larger supermarkets carry such lamps, they are cheaper there than at specialty stores.
Apr 09, 2015 | Refrigerators
Only copy a half of the paper
Check the exposure lamp light.Open the document feder cover,verify the lamp light(press the cover contact manually),if the lamp is light to half side,remove the glass,pull the scanner assembly in the left position use the alufolio and transparent scotch for repair the damaged parts.Verify the lamp ground continuity use Ohm meter.
Mar 06, 2012 | Konica Minolta DiALTA Di200 Copier
The light dows not work on my Sharo R254 microwave everything else is working. I gather all I need to do is change the light bulb but cannot find in the manual how to do it and what light bulb to...
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 10, 2011 | Sharp R-254 Microwave Oven
How do you change the bulb?
Hello :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
Here are the steps that explained in the manual :
Lamp Replacement Procedure:
1. Switch off the power to the projector by pressing the Power/Standby button.
2. Allow the projector to cool down for at least 30 minutes.
3. Disconnect the power cord.
4. Use a screwdriver to remove the screws from the cover.
5. Push up and remove the cover.
6. Remove the 2 screws from the lamp module.
7. Pull out the lamp module.
PLEASE RATE !
Apr 13, 2010 | Optoma EP747 Multimedia Projector
How Do I change the lamp on my Sony KDF55E 2000 TV
remove the cover on the side and remove the screw and lift up the latch and pull it out.
Nov 14, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Need instructons for changing Sony SXRD XL5300 lamp.
If you instructions manual you can download from Sony Web
Cheers
Dec 10, 2008 | Office Equipment & Supplies
Mitsu-wd-52527 lamp replacement
The lamp in this TV is very easy to change. I recommend to use your owners manual, but the front cover snaps off, using screw driver open lamp door, unscrew lamp, pull out with handle, make sure lamp is cool. Replace, follow onscreen display to reset lamp hours. Use remote to enter information.
Feb 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lamp/cover light blinking
Myn is a Sony 3LCD and it has just let me and game funs down ;Imagine Chelsea Vs Man U and this gadget projector won't turn on,th hall is full and my oh, the lamp cover buttorn fflashng and no light,, a zbiig let ddown
Oct 18, 2007 | Sony VPL CS1 Multimedia Projector
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
