Question about Saws
Milwuakee V28 cordless band saw runs in reverse.
    Master:
  • 534 Answers
Brushless motors can become demagnetized and polarized in reverse. Replacing the magnets may be the answer.
Posted on May 08, 2017
How to replace circular saw bearings
If you need to ask how to replace the bearings, you probably don't have the tools or expertise to do the job. Take it to a small tool repair shop and they can do it in a jiffy.
Aug 27, 2014 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
What exploded view of a milwauke drill
Check on ereplacements wesbite . They have an exploded view of your tool ; with part numbers/names.
Jul 21, 2014 | Milwaukee Tool Milwaukee 262922 M18 18Volt...
How do i open the motor to a black&decker 71&2 inch band saw ? my saw has started to make a lot more noise when runing
There are many reasons why band saw make noise. Here's are some "few checks" to do
1. Run the band saw without blade.
2. Run with a different blade.
3. Run the motor alone.
4. Check the bearings.
Another thing; incorrect speeds and feeds can cause noise and vibration.
Regarding about opening the motor, I can't help you with that. Try to check any other band saw motor manual reference.
I have Trajan 7x12 band saw, no vibration or noisy at all, I use Haltbar blade from sawblade.com
Jun 15, 2014 | Black & Decker Saws
The guide assembly on my 14" band saw will not stay peralell with the blade as it goes from the top of its travel to the bottom. it goes right to left going up and reverse going down the blade . the o
Sounds like something's bent. You might need some replacement parts. 14" band saws, regardless of brand, are generally made with Chinese parts that are knockoff Delta-Rockwell parts from many years ago. Grizzly sells most of these parts at reasonable prices. Check the exploded views of their saws to see if the parts match. Craftsman parts are expensive, even though they're the same part.
Mar 30, 2014 | Carter Products Rikon 14" Sears 14"...
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have a 6-1/2 "
go to milwaukeetool.com and you can download a copy of the owners manual with detailed instructions on this tool
Sep 02, 2011 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Band saw is going in reverse how to i fix that
The motor is AC (alternating current) and only runs in one direction. Therefore, the only way to reverse the saw blade direction is to flip the position of the motor 180 degrees. The teeth of the blade should be pointing down and face to the left when you are standing in front of the saw. The blade should travel down into the table so the blade pushes the work into the table. I hope this helps since it sounds like the blade may be installed incorrectly.
Mar 22, 2011 | Wilton 14in Woodmetal Cutting Band Saw
Broke off the head of the bolt that holds the blade on a 6 1/2 inch cordless 18v circular saw. How do I get the broken stud out?
If the threads are not bound, you might be able to use a sharp pick to work the broken part out. Otherwise, you will have to drill out the center of the bolt with a small drill bit and use an 'easyout tool' that will fit tightly into the drilled hole which will allow the piece to be backed out. Good luck!
Apr 15, 2010 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Blade running the wrong way
the field is in upside down, remove it and rotate it 180 degrees. Let me know
Nov 05, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Jan 29, 2009 | Saws
Saws Logo
70 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
