Question about The Audio Players & Recorders
Is Harman/Kardon HK3490 has DC(Direct Current) blocker on the audio inputs?
Benimur
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
naebarbat
  • 508 Answers
SOURCE: drivers for harman kardon en toshiba satellite P100
driver for Satellite P100-ST1071 here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1484723&rpn=PSPA0U&modelFilter=P100-ST1071&selCategory=3&selFamily=1073768663#
or try other model for P100-? from >downloads>model
Posted on Jun 05, 2009
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: harman kardon audio system for harley davison not calibrated
i have the harmon kardon stereo for harley and the sound keeps going out on it. This is the fourth unit that the same thing has happened too. Its like the unit goes into mute mode but its not. everything works but the sound. can u help me please.
Posted on Mar 03, 2010
Harman Kardon avr 355 has flashing L and R main speakers and wont play audio on anything other than the radio. Any ideas?
Switch the inputs from DVD to CD, or simply try another audio input. I use a Digital Audio Converter and RCA cables, it seems that one of the inputs (DVD which I used the most) has gone out. Same issue, if it sits for a week or so it doesnt save settings.
Oct 09, 2016 | Harman Kardon Audio Players & Recorders
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
I have a Harman Kardon AVR 210. When I first turn it on I get a humming sound from the speakers. All inputs. It lasts about 10 minutes and goes away once it warms up. Pls help.
It sounds like the power supply in your receiver has one or more filter capacitors that aren't working. They smooth out the voltage as it's converted from the AC (alternating current) provided by your electric outlet to the DC (direct current) needed by the electronics. The capacitors in your receiver are slow to charge up, and until they do the result is that hum you're hearing.
It's not difficult to replace bad capacitors, but the right tools and skills are needed. You should probably let a professional repair this unless you or someone you know is comfortable working with electronic repairs. Stereo retailers and musician's stores often have repair service available, or can recommend people to you.
Jun 26, 2011 | Harman Kardon AVR 210 Receiver
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
Fiber optics input not working
you will likely have to access the harmon kardon setup menu and direct the fiber input you are using toward the video or audio source selection which is being utilized along with it
Feb 22, 2010 | Harman Kardon AVR 7000
Can I conect harman Kardon avr 230 to apple tv
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
Need AC 15V 1.1A power cord for HK195 speakers
Hey, I was in the same situation. I tried a 9V DC (yes DC) converter I had and it works perfect. You can use a DC on a AC input - never the other way around. Due to insufficient power I get distortion at very high volumes... but I never play that high so I'm good..
Oct 07, 2009 | Harman Kardon HK206 Computer Speakers
No sound,no video,front panel display will display.harman kardon
Check your audio settings on the main menu of the receiver. The audio input should be set to "auto" Next, make sure you don't have the unit in "6 channel input" mode or "direct" mode. This is usually a small button on the front panel. If you check all this and you still have a problem, post a comment and I will help you troubleshoot some more. Hope this helps
Jun 30, 2009 | Harman Kardon AVR 140 Receiver
26 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
