Question about Definitive Audio Players & Recorders
My definitive technology pro cinema 600 sub stopped working
  • 197 Answers
Theres a setting is on the subwoofer itself, not the AVR. It usually has 3 positions: On, Auto, Off. Auto allows the sub to "sleep" when it's not being used, and to power back up fully when it senses a signal. Maybe change to On position which would bypass that auto mode
Posted on May 07, 2017
I tried installing a set of Def Tech Pro Cinema 600 speakers to my Yamaha RXV667. They recommend two methods. One is to connect the subwoofer through a cable using the LFE port on the receiver. I've done...
I'd go with the second method of connection for this receiver if you want to use automated calibration that requires discrete control of each speaker. I'd expect calibration errors with Method One as you're not just monitoring the sub when you test it; and the L and R fronts would have sub chiming in during the test, too. That would surely confuse the automation.
You (or the receiver) wouldn't be able to adjust the sub independently of the fronts that way.
I'd also be a bit leary of their claim you can set your speakers to Large. With only 3-1/4" drivers I wouldn't expect much in the way of realistic bass-handling or power dissipation.
From the manual...
"We encourage you to experiment with the various settings on your subwoofer, settings on your decoder, and hook-up options as described until you find the best combination for you."
Jan 24, 2011 | Yamaha RXV667 Receiver
Definitive Pro-Sub 1000 subwoofer replacement fuse.
Fit a 3 or 2.5 anything lower, if you can get away with it, but nothing higher.
However the chances are that it blew due to an overload, often caused by a shorted semi-conductor acting like it was a piece of wire. So even fitting a smaller one and it blowing again doesn't mean it's due to the rating.
Jun 25, 2010 | Definitive ProSub 1000 Subwoofer Speaker
BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
May 13, 2010 | JBL BP1200.1 Car Audio Amplifier
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Hooked up the system, subwoofer worked OK for about 3 hours then stopped outputting sound. Tried troubleshooting per manual but no luck. All other speakers appear to be working. I think the subwoofer died...
to make sure its not your reciever unplug sub from pre out side of reciever and with sub on run finger over the tip of the RCA you should get some kind of electral feed back from it through your sub if not then your sub or the amp inside is most likley fried if you know how to open the sub and can access it you may have a mini fuse inside that can be replaced but make sure consult somone about that and not just take my word
Oct 26, 2009 | Definitive ProCinema 600 Speaker System
Difinitive prosub 600 keeps turning its self off??? I have connected the sub every which way, low level RCA to sub out, using the prosub 600 as a bus for the front monitors, even both together. I have...
"Somthing seems to be wrong with the automatic on/off???" That's my guess too. Your sub requires a certain signal level to turn on, probably because of a sub-sonic filter. I just changed to another sub that did not have that "feature". Problem solved.
Jul 19, 2017 | Definitive SubAmp 600 Amplifier
Adjusting the subwoofer volume seperately from speaker volume
You can't exactly set volume but definitely turn down the bass which lowers the sub's output. Thats all we can do i think.
Mar 12, 2009 | Logitech Z Cinema 2.1 2.1 Speakers
Elite VSX-90TXV AV Receiver Installation w/surround sound & Plasma TV & DVD
Elite might have one or more wiring diagrams you could take advantage of.
Aug 22, 2017 | Audio Players & Recorders
94 people viewed this question
Top Definitive Audio Players & Recorders Experts
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
