Question about Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet
Fills but wont flush - Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet
    Problem Solver:
  • 16 Answers
Take off the lid on the tank. there should be a chain from the handle to a rubber flapper at the bottom of the tank. sometimes they fall off
Posted on Jul 27, 2009
When filling, the toilet makes a loud noise like a water buffalo dying and wont stop until I turn off the valve. whats the deal?
That miniature water buffalo may be living inside a clogged fill valve. It may be necessary to replace the valve to regain peace and quiet. If you do replace the fill valve, be sure to flush the water line first in case any debris is lingering.
Jan 09, 2017 | Home
MY TOILET WILL FLUSH BUT WONT FILL I CLEANED FLUSH VALVE AND VALVE HAS PRESSURE BUT WONT FILL TANK PLEASE HELP
Make sure the flapper is seating properly. If you can't tell, put some food coloring in the tank part... you will see color in the bowl.
Nov 02, 2014 | Danco Plastic Relief Valve Repair
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
Flushed toilet and wont stop flushing
take the back top off of the tank and observe that the flush stop has not released from its upright(flush) possition.
If needed , reach in and flip it down to close the valve.
If it is a matter of the water running continuously... then you have to open the tank cover and bend the rod that has the bulb on it down just a bit... to close the fill valve.
Mar 24, 2013 | Home
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
The top tank of my toliet wont stop filling. water is coming out of the flush lever??? I had to turn the water off to it
Your Fill Valve needs to be replaced. The life of the Fill Valve can be shortened by the hardness of water or by using tabs to keep the bowl clean. If it is a one piece toilet, use the Korky adjustable Fill Valve. If it's a two piece, use the Fluidmaster 400A. If you attempt this make sure you turn off the water supply valve and flush all the water out of the tank. When you go to tighten the plastic screw, be very gentle and don't overtighten because the tank WILL crack otherwise. Hope this helps!
Nov 26, 2010 | Home
Trans on my 02 wont shift out of 1st
The chrysler minivan is notorious for transmission issues. My wife had one and we put 2 transmissions in it before we decided that we had had enough. You could try to replace the trans filter and do drain and fill, but do not do a full trans flush as the car may never move again. Go here to read more about when to flush and not to flush your transmission
Dec 14, 2009 | Chrysler Town and Country Cars & Trucks
My hp printer wont print yellow
Hi I am Vortash use an old ink cartridge and fill it with ink flush .. insert it into the machine and flush all the old ink out of the print head .. it should do this automaticaly as you turn it on .. then still with the flush head in print a test page this will flush out any reamaiing blockages ... hope this helps regards Vortash
Jun 06, 2009 | Brother DCP-110C All-In-One InkJet Printer
Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet Logo
291 people viewed this question
Top Elite Home Experts
john h
Tom Chichester
Are you an Elite Home Expert? Answer questions, earn points and help others
