Had hepatitis 5 years ago - recovered, but still get sometimes a bitter taste in my mouth. What causes it am what can I do to prevent it or treatment. Gall or liver?
try to clean it external evaporator and internal evaporator of the machine maybe some left over water is stock in the internal evaporator that's why its cousing the smell.
The only thing I can think of that would cause one faucet to do that and not the other is the water line in that small stretch between them is a different metal. ie; galvinized to copper. If not properly adapted with a diaelectri or at least 4" of brass, it will cause electrolosis. Never seen electrolosis in action, so I'm not sure if it causes that smell and taste.
If you don't see a water line issue, then replace your faucet to see if that solves the problem.
If you have any further issues after that , I would suggest calling a plumber. good luck
I would check the temperature of water. Sounds like it might be too hot. The temp of the water should be between 192 and 197. Colder and its sour, and hotter and its bitter.
Have you been using the cleaning tabs regularly? If not, that is the first step. Second, if the time for brewing is too long then it goes bitter quickly. I time shots at about 11 seconds and add hot water after that. If you take taste tests for longer periods you can tell where it goes bad quickly and adjust the timer to stop at the right spot. Maybe timing changed. Have you had the wiring recall? If not, call Capresso and see if they'll still recall for free and they will also offer and exchange or full repair of existing unit.
