Question about Husqvarna Sewing Machines
Husqvarna classica 95 sewing machine does not do zigzag anymore. How do i fix that?
  • Husqvarna Master
  • 12,273 Answers
It appears to be an older mechanical machine. If so, most likely the moving parts are seizing due to lack of frequent oiling and cleaning. The problem will show up in different places on different machines. Some will affect the movement of the needle bar, others the feed dogs, others the stitch selectors, still others the handwheel, etc.
Wheel on right side that controls the needle up and down is very tight...
Posted on May 07, 2017
Husqvarna Classica 90 suddenly will not turn on
The power cord may have come loose at the machine end. Check that first and get back to me.
Jan 27, 2014 | Sewing Machines
I need a free manual for Husqvarna classica 90 sewing machine
there are no free manual for husqvarna machine, that I know of
here's a link for a manual--it's $8.00 +shipping
http://sewusa.com/Sewing_Machine_Manuals/Viking_Manuals/90_Classica_Instruction_Manual.htm
Sep 10, 2012 | Husqvarna Sewing Machines
My sewing machine won't zig-zag stitch
There is usually one source for this problem, and it's easy to fix. Take the end cap of your machine as if you were changing a light bulb. Now you are off...When you switch from straightstich to zigzag, the levers operate across and inside the body so that the needle shaft, you watch it going up and down, can also move sidesways (but only a few mm's (about 3/16 inch)) The needle shaft should both go left and right, freely. It is hinged at the top but half way down ththe shaft it "floats" in a two sided guide. This sounds complicated but it truly is NOT. What happens to neglected machines is that "gunge" forms in the sliding parts and stop the left and right deflections. You my need to prise open the shaft from it's guide to start with (be gentle) but a few drops of oil normally soon allows the needle shaft to slide side to side.
When you can shake the needle shaft from side to side BY HAND (with the machine set in the zigzag mode) replace the end cap and start zigzaging.
And in future oil your flaming sewing machine.....
Apr 29, 2012 | Husqvarna Sewing Machines
I am looking for a manual for a viking husqvarna
Call Husqvarna at: 1-800-474-6437. They may be able to get you a photo copy of the original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Sep 19, 2009 | Husqvarna Viking 1
Bobbins for Husqvarna Classica 100
classica 100 requires special husqvarna bobbins available from husqvarna dealers.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
52 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
