Question about Toro Garden
I need a blade driver belt diagram for toro wheel horse 8-25
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Posted on Jun 21, 2009
  • 8404 Answers
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
SOURCE: I need a toro z4200 drive belt diagram as my belt
I have the same problem and juts figer that out and put back on but still not working,
Posted on May 02, 2010
jyackle5
  • 8197 Answers
SOURCE: belt routing diagram
On link below on page 9 will show you the belt diagram.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L1001239.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Jun 22, 2010
Need installation diagram for 1988 toro wheel horse lawn tractor
Toro would be the source of the diagram.
May 01, 2017 | Garden
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
Need a manual for Wheel Horse 520-HC!
https://lookup3.toro.com/request/request.cfm Go to this website and put in model number and you can download a manual and parts book.
May 31, 2012 | Garden
What causes blades to run slow
I presume you are running the engine at appropriate revs :) .... Cutter belt is slipping. Is there any sign of oil on it? Is there tension on the belt?
Apr 23, 2012 | Toro 3 Blade Set For Wheel Horse 48" Deck...
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
Repace large belt on toro riding mowermodel14ap80rp744
Not sure what the problem or question is. How to replace the large belt?
Aug 19, 2010 | Toro 3 Standard Blades For Wheel Horse 50"...
I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Jul 18, 2010 | Toro Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Have wheel horse riding lawnmower that will not engage the blades
Take a look underneath, either the belt has stretched too much and its too long now or it has broke or fallen off. It could be that one of the pulleys have become frozen but you should hear squealing or the engine might stall. Good luck.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
