Question about Toro Garden
Lots of smoke on the toro timemaster 30 inch with oil leak near muffler or carburator
The gas is leaking through the carb float when sitting and filling up your crank. Drain it well and fill the oil back up. i installed a shut off valve and a shorter fuel filter on mine. In your case just don't leave gas in it for long.
Posted on Jun 29, 2018
  • 160 Answers
SOURCE: muffler blowing white smoke
take it back the engine has a blown head gasket or cracked head all cost over 1200 to fix
Posted on Mar 15, 2009
SOURCE: Lots of smoke coming out of Cub Cadet 2146 muffler
Check the dip stick to see if you over filled it.. You shouldn't have oil above the top line... If you did over fill it remove the dip stick and tilt the mower to the exhaust side to drain on the excess oil out of the dip stick tube...
If it's not over filled with oil the engine more then likely shot and it's time for a new mower..
Posted on May 21, 2009
  • 3567 Answers
SOURCE: too much smoke
Use TWO STROKE ENGINE OIL in the pump. If not using an automatic oil pump, then mix the gas and oil 32 to 1. That equals 4 ounces of TWO STROKE ENGINE OIL to one gallon of gas. NEVER use motor oil in the gas. Only two stroke engine oil. There may be an oil build up in the crankcase. Do a 64 to one gas/oil mix for awhile. Watch closely. when the smoke reaches proper levels go back to the 32/1 mix.
A “very helpful” rating for this answer? Thanks!
Posted on Jun 18, 2009
  • 130 Answers
SOURCE: Oil is leaking from the muffler and white smoke is coming out.
this is more severe.if you are not a small engine person 3 things get a book on mower or take to shop or get a new mower.
not trying to be funny but if you dont know its going to be hard for you to fix the valve guides are bad need to replace will take speical tools to fix.sorry
Posted on Jul 22, 2009
SOURCE: Lawn Mower smoking/mufler leaking oil
I have a yardman lawn mower that is two years old. It is now blowing oil out the exhaust and also blue smoke. Any idea what is wrong?
Posted on Apr 23, 2010
Toro timemaster is 3+ years old and doesn't self propel when you push the handle forward any longer.
Either the transmission is shot or the gears on the wheels that turn have been worn away;. They are plastic and do not last long nor take much abuse.
Apr 04, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Have a vibrations only when blade is engaged
vibration when the blade is spinning is a sure sign that the blade is bent and out of balance , maybe you hit something solid in the yard ??? anyways blades need to be replaced / rebalanced) if you continue to use a out of balance blade then shaft seal on engine will wear out prematurely and leak motor oil leaks out
Jul 29, 2015 | Toro TimeMaster 30" Self-Propelled Lawn...
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Jun 17, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
When I start mower it is ok for about 30 seconds and then a lot of white smoke starts coming out and small drops of oil start to drip onto body
It sounds like a lot of "blow-by" which means the rings or piston is leaking compression in high amounts carrying oil and water vapor to collect onto the vent where it drips.
Jun 16, 2010 | Garden
Distinct white smoke coming muffler area, we
i would drain the oil and re-check the amount you put back in.
May 02, 2010 | Toro Lawn Mower With Toro Power Tools
Smoke from snowblower muffler
Your gas to oil ratio is 32 to 1. Should cut down on smoke. replace sparkplug at same time.
Please rate this response and Good luck
Dec 29, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
210 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
