While going to print, a dialogue box appeared saying a data transfer error occured. what can I do.
SOURCE: out of paper light
I've been stuck with a flashing red paper light for a while. The printer could print from the manual tray and could also print test or diagnostic pages.
So I thought it might be driver related, and indeed it was.
There's a nasty setting in the printer properties that makes the printer go woo-hoo. So go to printer properties > tray settings. Check the "paper size" of "Tray 1". If it's set to "undefined", change it to your corresponding paper format. Click Update, Apply. Now print happily.
I still wonder why that setting magically changed. Hope this helps someone.
Posted on Nov 11, 2007
long1
  • 26 Answers
SOURCE: communication error
Marky12, if the printer works fine on the vista system then you can eliminate a hardware fault. sounds like a driver or install issue. remove the printer completely from the mac (uninstall software, drivers and unplug) then go to epson.com, choose your countrey and head to the support and downloads section. Get the latest drivers for mac/tiger and reinstall the printer (make sure you have restarted the mac in between uninstall and reinstall) and most important !!! dont plug in the usb cord until the driver install tells you to
Good luck
Posted on Feb 28, 2008
  • 10 Answers
SOURCE: printer is not printing
well you have to load the cd the printer came with onto your computer than go to options and see if it showed up than it should work
Posted on Jul 29, 2009
  • 66 Answers
SOURCE: error printing data is inaccurate, printing processing is stopped
what is th error
Posted on Aug 29, 2009
Nikhil Gedam
  • 87 Answers
SOURCE: When I try to print on my HP 2420 I get a box that says print
Uninstall the current drivers, install UPD PCL 5, and upgrade the firmware of the printer.
Driver for OS:
Operating System(s): Microsoft Windows Server 2003, Microsoft Windows Server 2008 W32, Microsoft Windows Vista, Microsoft Windows XP
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412142&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-35999-16
Firmware sw link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412142&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25074-6
Posted on Sep 09, 2009
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Mar 11, 2014 | Microsoft Visual Basic 6.0 for PC
Tip
Diagnose Quicken printing problems
Quicken printing problem mainly happens due to problems with printers. Check whether your printer is turned on properly or not. If turned on, check ink status and cartridges. If everything is fine, go to control panel of your computer, and open Printer dialogue box. Check settings and find whether printing machine has been detected by your computer or not. If printer is not detected, restart your system to get rid of the error. Printing data files of Quicken Customer Support also shows errors, when you try to printed non-updated version of data file. Updating data file will resolve the issues with precision. For more assistance, call customer support team of Quicken.
Quicken Customer Service 1 800 406 3148 Care Number
on Jun 14, 2016 | Miscellaneous
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
My printer cannot print]
Cristyjoyxeg:
When you click on the print box, the next screen will have a small dialogue box naming the destination printer. click on the small arrowhead on the right side of the box and a drop-down dialogue box will appear with your printer identified in the drop-down box. click on the choice that shows your printer and then click "print".
Aug 11, 2012 | HP Office Equipment & Supplies
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
Step2: Verify and Transfer faxes in memory
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
Step3: Reset the machine
After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
I am out of ink for blue and yellow and just want to print in black (i have plenty of black) can i keep printing. It keeps prompting me before i can resume to replace empty ink cartiages. I really need to...
Perhaps... when you click "print", and the Print Dialogue box appears, try checking the box "Print in Grayscale". It may work, it may not (it's your printer itself that is stopping the process, not windows).
If it's not the standard Word/Excel type program, you can also trying "printing to file" through something like "PDF-Adobe PostScript Printer", which will "print" to a PDF... transfer to disk/flash drive, and head off to kinkos!
Hope it helps!
Sep 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Each time I activate computer it prints out a test page
With a lot of the all in one printers they want to scan the test page aftert printing to check the alignment. Next time it prints out a page, if a dialogue box appears saying scan now with the option of scan or cancel, select scan. If a dialogue box does not appear, check the menu on the software and look for alignment. That should fix it.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
Brand new Canon MP210 wont print at all
Try going into Control Panel, Administrative Tools, Services and make sure that the print spooler is set to automatic.
Also make sure you have the latest drivers.
Click Here To Go To Canon Support
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Communication error
Good luck
Feb 28, 2008 | Office Equipment & Supplies
27 people viewed this question
jasbo
jasbo
