Question about Exercise & Fitness
My max pal cardboard baker has an issue. When crushing bale stops in downward ,motion full press then when you press up it continues to press down
3 Suggested Answers
  • 3197 Answers
SOURCE: craftman 1/2 hp chain drive , stuck in down motion
The thing to do is remove the cover and watch the limit switch assembly. You should be able to see how it is supposed to work and determine what is wrong. A small gear on the end of the shaft turns the limit switch assembly to make contact and turn off the motor in each direction. Something may be broken or out of place. There is also a possibility your logic board is bad especially if you have had electrical storms recently.
Posted on Jul 06, 2009
  • 3197 Answers
SOURCE: HBW077 Craftsman: door travels downward only 10"
Sounds like you have a bad RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it hits an obstacle but will act as you describe when they go bad. The part number is 41C4398A and is available at Sears or any good door service company.
Posted on Dec 20, 2010
Testimonial: "Great confirmation! Thanks. "
Erratic windscreen wiper action
sounds like the wiper control itself is playing up
Feb 27, 2014 | 2001 Nissan Micra
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
Belt wont turn.
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Press either incline key and the incline will calibrate automatically.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Jul 18, 2010 | Proform 380 CS Treadmill !
Seems to be stuck in a programcan't change speeds won't incline.have reset numerous times with no luck.
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
Jun 11, 2010 | RTO Image 15.0R Treadmill Walking Belt
Manual to trouble shoot/run diognostics
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 30, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Will not move belt
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Raditor cap won't come off
puish it down then turn it.to the left.....
May 04, 2010 | 2000 Pontiac Grand Prix
Press the peddle, and it only tries a little. won't work continuously
Make sure the machine has beemn oiled recently, undo the stop motion and press on the foot control and see if you have full power, if not you may need a new motor.
Feb 17, 2010 | Sewing Machines
Exercise & Fitness Logo
49 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
