Question about Akai PT5492S 54" Rear Projection Television
Akai 1080i hdtv 54in
T.v. abruptly shut off tried to turn it back on and it didn't make the usual tones indicating that the set was on instead it made a sickening sound like a dying baby bird. tried unplugging it unhooking all other devices but it still made the same sound. this set is only 2 years old. thank you for your assistance.
  • 934 Answers
Sounds like a regulator problem, possibly the low voltage side of the regulator. Could be the the regulator itself has shorted which in this unit is a STRF6628. If you're trying to attempt repairs yourself take a look at C834 100uf/25v next to the regulator and see if it's possibly open. If so replace it and see if the unit will power-up and let me know..
Posted on Nov 21, 2007
Fuzzy picture on tv 54in
Check your coaxial cable connection and inspect it wiggle it while the set is on if the problem clears replace the cable. Check to see if the male connector that sticks out the back of the set isint loose to the point where it moves when you touch it. If it does you need to have it looked at by a tech usually this problem can be solved with a little soldering but could get more complicated. Depending on the age of the set the fluid in the CRT's gets old and cloudy and light cant shine through it makeing your picture appear fuzzy. Your local tech should be able to change the oil in your set. Finally you could have some bad filter caps but I doubt it.
Jun 12, 2010 | Akai PTH5498 54" Rear Projection...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
Only reddish hue color for entire screen
In most cases these CRT projection sets made by Samsung for Akai are notorious for fouled cooling liquid in one or more of the CRT's. The CRT's in most cases are no longer available.
Aug 14, 2009 | Akai PT5598HD 55" Rear Projection...
Akai hdtv 1080i no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Sep 02, 2017 | Akai PTH5498 54" Rear Projection...
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Changing resolution settings
    Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
    Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
    Pitcture is Wavy
    Sounds like the tuner is going.
    Dec 05, 2007 | Akai PT4799HD Rear Projection Television
    AKAI 1080i HDTV 42"
    Aug 27, 2007 | Akai PTH5498 54" Rear Projection...
    Akai hdtv 1080i, No Sound
    I sounds like a bad filter in the sudio supply circuit finally took out the sound output chip or the power supply that controls the sound circuit. its a soliud state set and there are no user replaceable parts inside this set. Unless you have had solid state repair experience, please be safe and call in a pro to assost you in this repair. good Luck ps Please rate this thread
    Oct 19, 2006 | Akai PTH5498 54" Rear Projection...
    Akai PT5492S 54" Rear Projection Television Logo
    75 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
