SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
ERR
1 - Motor Movement
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
ERR
1 - Motor Movement
ERR1
from
the speed setting.
Analysis:
the
Tes the s. sensor for open or faulty. Clean it + tight the connector very well and try again. see the diagram for adjust.
God bless you
